Ice Maker is over filling and the cubes come out all connected together.
SOURCE: GE top freezer refrigerator automatic ice cube
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
SOURCE: Mine is a 7 -8 year old separate Freezer with an
none,this water cycle is controlled exclusively by the "mother-board/main-board in the lower rear area of the unit,the only other possibility would be is if the water solenoid valve isn't completely shutting off and letting water enter after a timed fill per the motherboards circuit timer or you are using the wrong ice cube tray(s) that may be of too small capacity,the boards new number is WR55X10942 made by G.E.Corp
SOURCE: I have a GE Profile fridge PSS25MGNAWW with an ice
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
