asic technical parameters for
Toner cartridge chip of Xerox Phaser 3450B:
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield of
Toner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print and
Drum chip for Xerox Phaser 3450Bhas mission paper pages count.You should reset
Drum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
- If you choose plan replace Drum chip then cost higher than reset chip. Each
Toner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan reset
Toner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenon
Toner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
"Tone life end", "Replace new unit"
The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:
"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,
"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device to
reset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :
Xerox Printer Support
Sir, My xerox wc5790 machine showing toner control system failure error with power down or ignore error while switched on the machine. Kindly give me the solution
Sir, My xerox wc5875 machine showing toner control system failure error with power down or ignore error while switched on the machine. Kindly give me the solution
