SOURCE: when starting car the rpms jump up to 2000 then
its becouse the cars computer tries to heat its self for it not to work when it is too cold
so just leave it there for a while till the rpm go to normal
by kevin
SOURCE: Cranking & Idle issue 92 Isuzu Rodeo
could be many things. Could be choke causing problems, could be engine temperature sendor bad, could be EGR. When you mean engine light comes on do you mean service engine light coming on? Probably has codes set which means something is gone wrong and setting a code that tells the tech what is wrong or what to look for. Have you changed your fuel filter lately?
SOURCE: 2001 dodge 5.9 diesel Cranks for 20 to 30 sec to start in morning
You have fuel runback.Replace the injector leak off pipes then try.If this does not work then have a non return valve fitted to your fuel supply pipe close as possible to the punp.Hope that was helpfull good luck.
SOURCE: when starting my 2001 jeep grand cherokee it revs
sounds like you have 1 of 2 problems either your TPS ( Throttle position sensor) or idle are control valve
Testimonial: "I thought TPS or MAF sensor. But they are about 100 dollars apiece. Thankyou"
SOURCE: rendezvous 04, the rpms stay idling high without pressing gas.
BUICK RENDEZVOUS IDLES UP REALLY HIGH...WITHOUT PRESSING GAS. WHAT IS THIS?
