I reduced the tension incrementally all the way to "0" and it still isn't working. I am not sure what to do. Is there a way to increase the bobbin tension? Or do I need to clean my machine (if so, how)? Does it need to be oiled (how)?
To clean the tension disks, set the upper tension all the way loose. Thread the machine from the top through the take-up lever with something like pearl cotton and gently pull the thread "down" (NEVER pull backward) through the tension disk. You can also lightly moisten the pearl cotton with denatured alcohol to remove any goo.
Then when you rethread the machine with regular sewing thread, be sure to RAISE the presser foot first. That action releases the tension disk so the thread seats properly.
If this does not work on your machine, then you may want to have it professionally serviced.
Consult your owner's manual for cleaning and oiling instructions.
Rethread top thread on the machine with a heavy weight thread or string, not threading the needle. Pull it out backwards and it will clean out the tension disks. You probably have threads and lint jammed in it.
