Any queries regarding Ip-details, please log in
to, http://www.ip-details.com/ which
gives you the latest information and a accurate solution for your
search.
Its like router on stick configuration??enter the interface which you have to configure and in that interface as mentioned below Hostname(config)#interface FastEthernet0/1 Hostname(config-if)#noip address Hostname(config-if)#no shutdown Hostname(config)#interface FastEthernet0/1.1 Hostname(config-if)#encapsulation dot1Q 1 native Hostname(config-if)#ip address x.x.y.y < subnet mask > interface FastEthernet0/1.2 Hostname(config-if)#encapsulation dot1Q 2 Hostname(config-if)#ip address x.x.y.y < subnet mask >
take the printer server host name and goto start run and put the \\hostname it will open the all shared items and right click on the printer and select connect it will install the printer............... or else you have to give a spacified IP address to the printer server.............
DNs (Domain Name System)
DNS is used for resolving mapping between IP addreses and host names.
Means when you quary for yahoo.com computer only recognize bits and bytes format so but dnd resolves this isssue when it got yahoo.com quary it send request to ip addreses of yahoo.com.
If you change dns ip to that then all quary goes to tht dnd server if it has info for your quary then it forwards to there other wise you get page not found.
The IP Address of the printer is required, and the HTTP option must
be enabled on the printer. If you do not know the IP Address, or
whether HTTP is enabled, print a Configuration Report. See the Related Items
below for additional information. If you do not have this information
or the printer is not configured correctly, contact your System
Administrator for assistance.
A user account for the scanner to login to the scan server must be
created (account needs full control access rights). The user needs to
be a local user on the workstation and not a domain user.
NOTE: SMB uses local rights and not domain rights. Record the username and password for future use.
A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
The Hostname of the workstation must be known.
CentreWare 5.5x must be installed on a Microsoft Windows server or workstation on the network.
From the workstation or server where CentreWare is installed:
Click on [Start], point to [Programs], select [Xerox CentreWare],
and then select [Add Network Scanner]. The Add Network Scanner Wizard
window will be displayed.
Click on the [Enable a new Xerox System Scanner for network
scanning and associate it with a scan server] radio button, and then
click [Next].
Select [Specific IP Address] from the Find Devices pull-down menu and continue with step 4, or select [Specific TCP/IP Hostname] and skip to step 5.
If Specific IP Address is selected, an IP Address field will be
displayed. Enter the IP Address of the printer in the field, click
[Next], and then skip to step 7.
If Specific TCP/IP Hostname is selected, a Hostname field will be
displayed. Enter the printer’s TCP/IP hostname in the field, and then
click [Next].
NOTE: Select Specific TCP/IP Hostname if the Printer is using DHCP to resolve the IP Address and has a Hostname assigned.
If the printer has been configured for Scan to File, a window will
be displayed with a 'This device has already been configured for
network scanning. Continuing will overwrite its current configuration.
Do you want to continue?' message. Click on [Yes].
The Enter Password window will be displayed. Enter your system
password in the field provided, and then click [OK]. The Server Type
(Filing Protocol) window will be displayed.
NOTE:
The initial system password at machine install is 1111. If the
administrator encounters a problem with changing the password, or
forgets the password, a service call must be placed.
From the Server Type (Filing Protocol) pull-down menu, select [Windows (SMB)].
Click on the [Browse] button located below the Location
(\\Server\ShareName\Path) field. The Choose Location – Windows (SMB)
Browse to the server and then to the Scan folder where the
CentreWare scanning folders will be installed, and click [OK]. The
Location field will be displayed with the scan server name and the path
to the shared scan folder.
Click [Next]. The Xerox System Login Name window will be displayed.
Enter the scan user name and password (this is the user account the
printer will use to login to the server share) in the fields provided,
and then click [Next]. The Distribution Server window will be displayed.
Do not make any changes. Click [Next].
Click on [Manage User Templates]. The Manage User Templates window will be displayed.
Click on [Modify Template List] to begin selecting template users
for this scan server installation. The Modify Template List window will
be displayed.
Make a selection from the list of Users and Groups, and then click
on [Add] to create a scan folder and template for the selected user or
all members of a selected group. If necessary, repeat this step to add
additional users or groups.
When you have finished, click [OK] twice. The Finish window will be displayed.
Click on [Finish] to upload the scan settings to the printer. The
Add Network Scanner Wizard window will close when the settings have
been uploaded.
Just to verify, you are trying to connect from a computer external to your network to a computer on your internal network, right?
The error you mention is thrown if the name in the remote asstiance file cannot be resolved by DNS. Open the remote assistance file you generate in a text editor like notepad and then look for the value next to "RCTICKET=". This is name name & IP of the computer requesting remote assistance. If you're trying to connect from an external computer, make sure of the following:
On your router, forward TCP 3389 to whatever IP you're trying to access
That the hostname listed is able to resolved externally (it needs to have a fully qualified domain name list somehost.somedomain.com not just somehost'
The IP address is not a private (192.168.x.x or 10.x.x.x) address but a publicly accessible IP address.
Step 1 Open your web browser and enter the IP address of your D-Link router (192.168.0.1). Enter username (admin) and your password (blank by default).
Step 2 Click on the Home tab and then click DHCP on the left column.
Step 3 Under the Static DHCP section next to DHCP Client, select one of the DHCP clients from the list and click Clone.
Step 4 Select Enabled and enter the IP address you would like this client to always obtain.
Step 5 Verify that the Name and MAC Address fields have the correct Hostname and MAC address for the client and click Apply. If the Hostname or MAC address is not correct, Release and Renew the IP address on the client and then refresh the DHCP page.
