Follow to Clear Canon Printer Error Message E13 and E16 Code for effective printing. Canon Inkjet Printers works on basic on counting the number of pages printed and calculate the page covered in order to determine how much the ink cartridge is present. The Error message E13 and E16 error message arrives when it is believed the printer cartridge ink has run out of indicating that you need to change or install the all new ink cartridge. If this error message is being displayed on your printers screen then your printer will stop printing and scanning as well. The error message E13 and E16 is most commonly and noticed one when someone is using a refilled or remanufactured cartridge as they will read it as low or empty immediately. The affected cartridges have no means of detecting fresh ink within the cartridge. Or follow the steps top resolve the message or connect to Canon Printer Technical Support for any query.
Steps to Clear Canon Printer Error Message E13 and E16 code:
Step1: Skipping the message
The Canon Printer overestimating tendency of how quickly ink within their cartridges run out and if you have received this message you will certainly have some ink left. Gratefully the arrived message can be overridden and you can continue printing with the press of button. Only you need to perform some steps:
·Locate the STOP or RESET or RESUME button on Canon printer machine which is signified by a triangle within a circle on the body of the printer and is usually in red, white or black.
1 8002138289 Canon Printer Technical Support Blog News For Printer Help
·Hold the reset button after locating at least for five seconds and then release it. This simple prompt signals to your printer that you are aware that the cartridge may have run out of ink, but would like to continue printing regardless of any fact.
·Canon printer will now continue printing without an on-screen ink level estimate until the ink in the cartridge has physically run out. At this particular point you need to notice the print quality issues, indicating the cartridge genuinely needs to be changed.
Step2: Check for any further damage caused to Printer
It is a myth there is no chance of getting your Canon Printer damage. Although continue use of the empty cartridge does put strain on the print-head and can cause damage. As this range of printers dispenses ink directly from the cartridge to the paper thanks to the print-head built into each black/color ink cartridge. In the very worst condition the print-head may burn out with extended use, but if you replace the continually used cartridge soon the cartridge can still be used again once after refilled.
Following Models are covered for Error message:
·Canon PIXMA MP160
·Canon PIXMA MP450
·Canon PIXMA MX300
·Canon PIXMA MX410
·Canon PIXMA iP2700
·Canon PIXMA iP2400
·Canon PIXMA MG3250 When you are working on the error message yet you fail to get the issues resolved contact Canon Printer Support Phone Number 1-800-213-8289(toll-free) to get guidance in right direction. The well-trained qualified technicians are here to resolve your error message or query arrived while resolving the error via following above mentioned steps.
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Clean the print head then print a demo sheet.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
