Gas gauge says half full
Search Results
P0507 Mercedes-Benz - Engine-Codes.com
engine-codes.com/p0507_mercedes-benz.html
Possible Causes and Repair Information for P0507 Mercedes-Benz code. Learn what does P0507 Mercedes-Benz means? P0507 Mercedes-Benz Idle Control ...
Either that season's gas dried in the carburetor affecting it's operation or you are drawing air through a fuel seal somewhere. Both are common with this model. Sometimes will start from cold and run up to half speed until you take the choke off. Then it just dies from not drawing gas. Status proved if it revs up if sprayed with short blip of ether from 7" away at the moment it dies. Do not try to keep it running on ether more than a minute. Like pure gas, it'll burn up the engine or worst. Do not use ether if the air is not moving. Ether may collect and explode.
