Apple iPad 4th generation Logo
T
Tracey Crews Posted on Jul 31, 2015
On my Verizon email my general settings won't save my new information I've typed in. I'm using an iPad 4 on the Verizon email site and I can't save anything I've typed.
Add email addres
  1. Tap the Settings icon on the Home screen.
  2. In the Settings dialog, tap Mail, Contacts, Calendars.
  3. Tap Add Account.
  4. Tap Gmail, Yahoo! ...
  5. After iPad takes a moment to verify your account information, tap Save.
1helpful
HOW DO I SET IT UP TO RECEIVE MAIL ON IPAD
1. Tap Settings
2. Go down to Mail, Contacts, Calender
3. Tap add account
4. Select your email provider. If you don't see your email provider listed, tap Other > Add Mail Account.
5. Provide the required information to finish adding your account.
If you use a common email provider, your device will load your email settings automatically.
Ipad screen not rotating
Hit home button 2 times then slide ur finger copper and click the cerved arrows
Nexicom.net email setup on ipad
You have to go into Settings -> Mail, calendar ... and add a new mail account as "Other". Put in your email address anywhere you see user name. Choose the POP type of account - IMAP won't work. Use the following for settings:
  • incoming server: mail.nexicom.net
  • user: your email full address
  • password: your password
  • outgoing server: outgoing.nexicom.net
  • user: your full email address
Tap "Next" and it will likely fail and ask if you want to connect without SSL. Tap "Yes" and you should get all green checkmarks and mail should now work. :v)
2answers
How do I know if my iPad is an IPad 2 or 3
check the model nr. on the back side:
Apple Device Model Number
1iPad Wi-Fi (Original/1st Gen)A12191
iPad Wi-Fi/3G/GPS (Original/1st Gen)A13371
iPad 2 (Wi-Fi Only)A13951
iPad 2 (Wi-Fi/GSM/GPS)A13961
iPad 2 (Wi-Fi/CDMA/GPS)A13971
iPad 2 (Wi-Fi Only, iPad2,4)A13951
iPad 3rd Gen (Wi-Fi Only)A14161
iPad 3rd Gen (Wi-Fi/Cellular AT&T/GPS)A14301
iPad 3rd Gen (Wi-Fi/Cellular Verizon/GPS)A14031
iPad 4th Gen (Wi-Fi Only)A14581
iPad 4th Gen (Wi-Fi/AT&T/GPS)A14591i
iPad 4th Gen (Wi-Fi/Verizon & Sprint/GPS)A14601
iPad Air (Wi-Fi Only)A14741
iPad Air (Wi-Fi/Cellular)A14751
1helpful
What is the easiest way to import MS Outlook (addresses, telephones, mail etc) from my laptop to my new ipad
Connect your ipad to an exchange server. You can do it by following these instructions:
. From the Home Screen, tap Settings
2. Scroll down and tap Mail, Contacts, Calendars
3. Select Add Account > Microsoft Exchange.
4. Now type into the following information:
* Email: your email address
* Username: your-Exchange-User-name
* Password: your-mail-password
* Description: It's Optional
* Server: ****.com
Your username is the one you use to access mail at work.it could be firstname and initial like (robd) for example or it could be your email address. Next, the server field you put in the server to connect to. Every business has a different name for this field. You should ask your IT dept. if you are unclear what your account credentials are to fill in these fields.
But once you are connected to the server, you can specify what you want to sync onto your ipad. Contacts will be found in the address book under "Groups" these contacts will than pull from your exchange connection.
Hope some of this helps.
How can i set up my Ipad to use Microsoft Outlook email. Kind Regards Duncan
I assmume you mean through an exchange server? My guess is you want to pull your work email?
Here are the steps:
* Server: ****.com
Now, if unsure of what your server name is, contact your company's IT support for that information.
Thanks
I have just got an iPad 32GB. I wish to move all my emails from my PC to the iPad i.e. my Outlook mail folders, all the emails in those folders etc. Can this be done ?
You will need to setup a Exchange mail account on your ipad to receive all the mail and calendar items that you see on your Outlook mail and calendar.
Here is how to add an exchange account:
* Server: ****.com
For your username, and server names, you will need to contact your company's IT department for the credentials. But your username is the one your IT dept. gives you for email access and password. exchange server name is the server address to access your mail.
1helpful
Can't set up mobile data plan for new 3G iPad
Follow these steps to set up your new Cellular Data account :
1. Tap Settings > Cellular Data > View Account:
2. The Cellular Data Account management window loads. Enter information or select an option in the following sections and tap Next when you are finished:
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--cellular_data_account-004-en.png
User Information Enter your first and last name and your phone number.
Login Information Enter an email address and a password. This creates an AT&T account, allowing you to log in to the account later to make changes or view your usage statistics.
Recurring Domestic Plan Options This allows you to choose the type of plan you want to use.
Payment & Billing Information Complete this section with the billing information you’d like to use to pay for your Cellular Data account.
You can tap "Use a different service address" if you're billing address is a P.O. Box or Rural Route, and enter an alternate address for your service address
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--cellular_data_account_service_address-001-en.png
Note: You cannot use a P.O. Box or Rural Route for the service address. AT&T requires that you use a street address for the service address. Please see this Document from AT&T for more information.
3. The Terms of Service agreement loads. Take a minute to read this agreement. Tap Agree to continue.
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--terms-002-en.png
4. The Payment Summary loads. This shows you a summary of the account and plan you have selected:
ht4157--payment_summary-003-en.png Note: You can also add an International data plan on this screen by tapping Add International Data, or you can access your account later to manage your plan options. If you need to use your iPad internationally, you must sign up for the international data plan while in the United States.
5. Tap Submit to complete the creation of your Cellular Data account. The Congratulations screen loads. This lets you know that your account has been created, and that AT&T is activating your iPad. Tap OK to finish and return to the Settings screen of your iPad Wi-Fi + 3G.
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--congrats-002-en.png
Your iPad will notify you when your Cellular Data connection has been activated :
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--data_plan_activated-001-en.png
While waiting for this activation, you can use your iPad Wi-Fi + 3G on Wi-Fi.
Additional Information Note: The Cellular Data account sign-up process is managed by AT&T. If you have questions, concerns, or problems with this sign-up process, please contact AT&T.
If you need to change or correct your email account information, please contact AT&T.
Note: A unique email address is required for your AT&T account. If you plan on setting up cellular data accounts for multiple iPads, you must use a different email address for each account.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
