Empisal Super Star sewing machine uses a set of stitch pattern cams to create different stitches. If you need stitch pattern cams for your Empisal Super Star sewing machine, you can try the following options:
Check with the manufacturer: Contact the manufacturer of the Empisal Super Star sewing machine to see if they still produce or have stock of the stitch pattern cams.
Check online marketplaces: Look for online marketplaces that sell vintage sewing machine parts, including stitch pattern cams for Empisal Super Star sewing machines. You may be able to find them on websites like eBay or Etsy.
Check with a sewing machine repair shop: Contact a local sewing machine repair shop or service center to see if they have any stitch pattern cams that would be compatible with your Empisal Super Star sewing machine.
Consider alternatives: If you are unable to find the original stitch pattern cams for your Empisal Super Star sewing machine, consider using alternative stitch patterns that do not require cams. You can also consider purchasing a newer sewing machine that has a wider range of built-in stitch patterns.
It's important to note that not all stitch pattern cams are compatible with all sewing machines, so make sure you check that the cams you purchase are specifically designed for the Empisal Super Star sewing machine model.
copy and paste the following into google
https://www.google.com/search?q=download+manual+for+King+Star+sewing+machine+KS+8700&oq=download+manual+for+King+Star+sewing+machine+KS+8700&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Check out the manual for the White 2200 or 1927. One or both could be close enough to your model to be helpful. Machines generally didn't change a lot from model to model.
If you don't mind spending $14. 95, sew 4 less sells manuals for almost any machine, and they do have the brother star 15 http://www.sew4less.com/product/4259/Brother_Star_15_20_Instruction_Manual Brother Star 15 20 Instruction Manual
My brother XL-3030 will not sew, the light comes on but the machines does not engage to sew when you press the foot pedal. Plus the led screen is blank. Is it the internal computer or the power cord?
You can check this out. Doesn't list your model, but it is most likely similar to the 120 and 140. Usually, the only difference between one model and the next is one will have a few for stitches or added functions. The basic operation is probably the same:
