Televison & Video Logo
A
Andrew Bundy Posted on Jul 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv is on the photo screen and can't get it back to normal tv. I've tried everything and nothing has worked
Jim Dowell
Level 3:
Master:
  • Master 345 Answers
  • Posted on Jul 31, 2015
Jim Dowell
Master
Level 3:
Master:
Answers
345
Questions
0
Helped
121311
Points
1057
The source button on your remote should cycle thru the various inputs. If it doesn't respond make sure the lock button (child lock) hasn't been pushed and engaged on the remote.
1helpful
Hello, I have a Samsung LN52B630 TV that quit working...noticeably after a confirmed lightning strike nearby.
Screen coming on when the main plug is removed is normal, that happens on most TV's...Are the spots that have no volts supposed to have voltage? there is a legend on the board to tell what voltages belong no what pin, check that
My flat screen is stuck on the photo screen and i have tried everything, to get it back to normal tv and nothing has worked on it.
Try a hard reset, and check. If it do not help, check and replace its main system control memory IC. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
My yobo console will not start up.
You have a bad console. These are made rather cheaply and do fail out of the box. Surgest you take it back to where you got it from and exchange it.
Iphone stuck on itunes screen with usb
First power off your iphone and restart it does it start normally or not.
Secondly restart your iphone without connecting to computer. so remove usb cable and restart your iphone ipod or ipad. Even though iphone stuck all logo and itunes and usb symbol then it is a issue of original sim
Secondly when you connect iphone to computer and it detected as recovery mode then your ipod iphone is not properly restored. Here is how to restore ipod / iphone or ipad.
Imac to jvc
Hi. A couple of things to try.
Switch everything off. Make sure your connections are sound then switch on the TV. Then switch on the mac. With luck the system should sort itself out. However, I have heard of others who have had nothing but grief trying to get similar arrangements to work.Normally ther Mac does it's own thinking, works out what is at the other end and puts up the display without any problems - other than the picture width being invariably wrong until you find the correct size.
There are no drivers to download - the issue is generally that the TV is not reporting back to the computer the correct resolution and scan rates.
You may have to dive deeper into the TV's menus to locate the means of altering the parameters.
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
I have a amd ahtlon 7550x2 daulcore bundle. i have windows 7 ultimate running on it. graphics card ati rad express 2100 and running it off my tv. i get the blue screen of death when i try to load the...
Hi normally the bluescreen of dealth would incate there is a problem with your hard drive or the file system as become corrupted.
Have u tried the hard drive on another PC ?
I ve got a sharp aqueos tv i turned oevr channels
Try this: unplug the power cord from the wall, let TV set stand for AT LEAST 30 minutes, then plug back in and and see if the TV operates as normal.
Sometimes this works and sometimes it doesn't.
Good luck !
2answers
No picture any more
if your tv has a light blub replace it this is only for hdtvs
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
