Compressor runs continously and inside temperature is good. Temperature control has been turned down to original factory setting of 4 and it still runs constantly
Try cleaning the unit out and any coils you can reach (typically located near the bottom of the unit behind the toe grille). Do you hear the compressor running? The compressor is constantly meant to go on and off frequently to keep unit at a constant temperature. If you do not, the unit could possibly have a coolant leak or an issue with the internal sealed system including a faulty compressor, evaporate fan or main control board. Contact a professional move forward accurately.
For manualsonline.com
Hi monilvsjay - Typically when the freezer is beeping it indicates a warning of a possible malfunction or an unsafe temperature inside. The silence the buzzer, press the ALARM OFF button, however if you have already done so try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. The freezer could possibly be experiencing a communication problem with the temperature control/board or wiring failure.
At first freezer suddenly would not cool blow 23F, while running continously. Now the temperatue guage on the door indictes 01F and the freezer is not running. Also, I can not reset te temperature
