SanDisk Sansa e200 MP3 Player Logo
K
Kimberly Brown Posted on Jul 30, 2015
Turns off after about 15 minutes of play. Can't get to turn back on. Replaced battery, turned on automatically. Now it's
Done the same thing and I can't get it to start. held down power button for 30 seconds to restart. Still won't turn on.
5 Related Answers
Anonymous
  • Posted on Sep 16, 2007
SOURCE: snasa e260 wont load up
the link for the firmware does not pop up it just says sorry your page.....
A
Anonymous
  • Posted on Mar 03, 2008
SOURCE: Sansa e250 will not turn on
try buying a new charger and did you knw that you can also use a apple ipod charger
Anonymous
  • 61 Answers
  • Posted on May 27, 2009
SOURCE: Screen is off. It's frozen.
Holding the power button for 20 seconds should reset it.  Otherwise, there are many solutions on the support page here.
Anonymous
  • 4 Answers
  • Posted on Aug 25, 2009
SOURCE: blue ring of death
I had this problem with my Sansa e260. I was unable to enter Recovery mode, and was unable to find a working copy of the Linux based "e200tool". Out of desperation, I tried re-seating the so-called "daughter board" and it worked. The player is now as good as new.
All you need to do is, remove the 4 screws on the back of your player to reveal the battery compartment. Just above where the battery is, you should see a black, foam rectangle. Press gently on this rectangle until you hear/feel a slight click (this is the card re-seating). Then try to power your unit on. Worked like a charm for me.
Good luck.
Anonymous
  • Posted on Nov 23, 2009
SOURCE: My Sansa e200 will turn on, thumbwheel is blue and
sandisk sansa e250 starts but then says refresh database. Menu is in back ground. Maybe frozen, and have tried to reset, but still come up with Refresh database.
1helpful
The battery replaced by new one and fully charged .How many hours will last playing the iPod
#2
That sounds about right, using Wi Fi does use a lot of battery. For video, Apple advertises up to 5 hours, and for audio up to 36 hours. However, these are done in minimalist conditions. For example, they?d have auto-brightness turned on, the volume at only a certain level and, if it?s music, they?d turn the screen on only when absolutely necessary (yes, volume does have an impact on the battery).
I used to get around 12 hours listening to music, but that was because I always have Wi Fi on, and also have it set to fetch my email every 15 minutes. Oddly, since jailbreaking, it took me about 20 hours to completely drain the battery. That included using the internet (mainly Facebook) quite a bit, checking emails, listening to music, watching videos, AND playing games (well, emulators).
2answers
Why signal light wont turn off in 94 325i BMW
Do you mean it won't automatically switch off after you turn, or do you mean it stays on, either flashing or just permanently on?
If it's the 1st one "doesn't automatically switch off after turning" it sounds like your turn signal stalk is broken & needs replacing.
If it's a case of the light just continuing to flash or stay on well then it could still be your signal stalk or the relay which times the lights to flash on & off.
All these bits can be purchased for little money on eBay
2helpful
My jenson mp3 model smp-2gbl wont stay on
i have a jensen model# smp 2 GBL it wont play it comes on for a second then turns off. I took out the music put in new music then it played for 5 minutes then turned off and does the same thing again. I put in alot of new batteries that dont work either can you help me
Calculator won't turn off with new battery installed.
If they are solar powered and if the power down button is not functionning I would not worry about them. Usually battery powered calculators have an automatic power down feature, and sometimes solar powered machines as well. The only free thing we get is the sun's energy. Maybe not the only one (oxygen).
Hope it helps.
System turns to red light standby in the middle of playing
you need to go to your setting and change your automatic shutoff timer. this will cause your system to turn off every 15 minutes no matter what you are doing...
Hope this helps... please rate...thanks
4helpful
3answers
2001 Galant service engine light on & won't stay running/ runs rough
Try this: Disconnect the ecm control (where the air filter is housed)
Let me know if that worked.
60helpful
11answers
Wii console will not come on
First things first. We'll start from the beginning. Unplug the AC Adapter from the wall and from the Wii. Let it sit for 15 minutes. Then plug it back in. 9 times out of 10 your power supply needs to be reset. The only way to reset it is to unplug it from the wall and the wii and let it sit for 15 min. Try this first and report back if it worked. Even if you think you have done this already do it again.
Sony psp problem
Remove the battery for 15 minutes, connect the AC Adapter and install the battery again.
It that doesn't work, remove the battery again, wait 15 minutes, install it and plug the AC Adapter.
It's a weird problem but in my PSP i get around that way.
1helpful
2answers
Help Me
on Dec 20, 2007 The_ The_Ogre posted:
Remove the battery cover off the back of the unit. (One small Philips screw.)
Remove the battery.
Leave the system without the battery for 10-15 minutes.
Replace the battery.
Re-install the battery cover.
I've tried and it works. Thanks to The_Ogre
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
