press '2nd' and the M+. p/np = Print or NoPrint. The button '2nd' is for the second fonction, when press, it will allow you to choose the fonction on top of the button.press '2nd' and the M+.
You can't post conmments that contain an email address.
Hi On the control/operator panel press and hold the <ON/OFF> button for one second.[Unplug machine if it doesn't shut off after pressing the <ON/OFF> button]. Wait like 10seconds and press the ON/OFF button again. The machine starts cycling. Wait until it finishes and then try printing.
When you change the drum you must reset the drum count.
1: press ONLINE button once. The lcd display will read offline.
2: press MENU button until the lcd display reads MAINT. Menu.
3: press ITEM+ button twice. The lcd display will read drum count reset.
4: press SELECT button once. this will save the drum count reset.
5: press ONLINE button once. You will notice the Change Drum Message
has disappeared. You should be able to print at this time.
When it says "DATA ERROR", press any key. Next, you should get prompted with "INITIALIZE?". The key to solving this problem is to press the "SET" key. Turn off your label maker, then turn it back on. Should be back in action now, enjoy!
The 8 beep error you are getting is a waste ink tank full error. The BJC 85 has a waste ink " tank " that is actually a series of absorbent cotton pads in the bottom of the printer. When these pads fill with ink, the printer is designed to produce that error and stop printing until the pads are replaced.
I can give you a work around to this and get you printing, but you must understand that, because the waste ink absorber is full, ink will eventually start leaking out into the bottom of your printer and either leak out of the printer, or end up shorting out the main circuit board , which is also in the bottom.
Here is the work around that will reset the printer and get you printing again:
1. Shut off the printer and unplug it from the power supply.
2. While holding down BOTH the POWER and RESUME buttons, plug the power supply back in. KEEP HOLDING DOWN the buttons until after the printer does it's initial actuation and then goes quiet again, then let go of the buttons. .
3. With the fingers of one hand Hold down the RESUME and CARTRIDGE buttons and with the other hand hold down the POWER button. Listen for 2 BEEPS. they will not be loud, and one will be longer than the other. When you hear the 2 beeps, let go of all the buttons.
4. Now press the CARTRIDGE button 15 times. You will hear a beep each time it' pressed. Make sure you count the beeps correctly.
5. After you have pressed the cartridge button 15 times, then press the RESUME button. The printer will beep and shut off.
6. Press the POWER button and the printer will power on and be ready to print. At this point, the printer will have been reset to indicate the waste ink is 50% full.
If you make a mistake, you can unplug the prnter and start over from step 1 at any time.
REMEMBER: Your waste ink pads are still FULL. You need to either replace the pads, or replace the printer before to much time goes by. If you see any ink leaking out the bottom of the printer, definitely stop using it.
The first thing you need to do is Press <Black> or <Color> button to clear the error and continue printing. If still the device is not functioning properly or to clear memory, reset it.
On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
Wait approximately ten seconds and then press the <ON/OFF> button again.
Wait until the device has completed its cycling process before submitting another job request.
Please do rate this solution as FixYa and revert for further assistance.
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
Bask11, sounds like the printer needs to regap itself. Turn the printer off, hold the feed button down and while holding the feed button, turn the printer back on. As soon as it flashes, let go. It will regap itself. When it stops moving, press the feed button once and there should be a priinted line that says 'out of dump'. The printer should be ready to go then.
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode.
When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
