SOURCE: wii console
Did you try turning the disk over so the label shows on the opposite side. With the Wii you have to put them in upside down it seems.
SOURCE: wii game disc's not loading
The lens in your wii disk drive might be dirty or scratched. Try putting in a regular head cleaning cd. The problem is that the wii will not read it but it might spin it round enough while trying to read it to clean the lens. You could also do it manually by taking your wii apart but i wouldn't recommend it personally due to the large quantity of things that break easily and the amount of screws to be taken out that are easy to lose.
Hope this helps,
Mowcius
SOURCE: wii console
If it only clicks when you put a disc in then it is out of balance and the sound is your disc smacking around inside a bit. Usally the drives will fail soon around that time
SOURCE: wii makes a buzzing sound when discs are running
The noise is the wii working extra hard to read the disk the lens might be dirty. Your wii might also have a bomb in it.............Just kidding. I would try cleaning the inside and if all is bad send it in to get fixed
