Watches Logo
D
Deane Hoffman Posted on Jul 29, 2015
How do I get the back off of a Lucien Piccard watch. It has 6 notches on the back, but I cannot turn it at all. Please help.....
I think it just needs a new battery, but can't get the back off.
5 Related Answers
Anonymous
  • 2071 Answers
  • Posted on Jun 14, 2008
SOURCE: Need New Watch Band
i have repaired watches like this before. I advised u to go to www.the watchery.com and www.lucienpiccardusa.com or www.ebay.com. there u can buy and choose branded lucien piccard watch band.let me know if u see what u wanted...
Anonymous
  • 109 Answers
  • Posted on Oct 28, 2008
SOURCE: lucien piccard watch
The arrows you are seeing are for sizing the band. I cannot find 26311SS in my data base, but I have a good idea what you need to do. The curved piece is a safty that goes over the clasp. Take something like a round toothpick and with the curved piece going to the right like this: ( put the toothpick under the far lefthand side, in the middle and see if you can pry it up ,( I say use a tooth pick so not to scratch up your watch) it should flip over to the right.Check and see if there are any spring loaded buttons on either side of the clasp, if there is push them in ,and lift to your left If there is no buttons just pry up towards your left. If this dosn't work PLEASE let me know, and I will find the exact watch and we can go from there. Good luck!!
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 07, 2009
SOURCE: Add links to a Lucien Piccard 26006SS
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Anonymous
  • Posted on Sep 07, 2009
SOURCE: Replacing Batteries on Sealed Watches
Who ever told you that story about throwing it away should not be in the business of repairing watches. I have the same problem and googled Lucienpiccardusa.com. They do lifetime battery replacement and some general servicing according to your warrenty. From what I read on their web site you only pay for the shipping charges.
Hope this helps you. JFG
Anonymous
  • 2501 Answers
  • Posted on Jan 07, 2010
SOURCE: Lucien Piccard 27094bk manual
Go to the web site "lucienpiccardusa.com/"
From the menu on the left select "customer care".
Scroll down the page until you find "instruction downloads"
Choose "three stage movement instructs"
If this is not quite what you need, you could email them.
Lucian Piccard Watch with serial number G26897 - date? value please?
Question edited for clarity, 'make model (what is is)', and throw in a few capital letters.
Question moved from Computers category to Watches.
No one here will know that, and prices on secondhand watches can wildly vary. Contact the maker for the date. Contact local jewelers for a value. or a site like this
https://www.marks4antiques.com/price-guides/Lucien-piccard-vintage-watches.htm
General Help - Lucien Piccard ·
http://www.lucienpiccardusa.com > help
General Help. How do I contact lucienpiccardusa.com? Please contact us at 1-866-746-7794, Monday to Friday from 9am to 5pm EST. Or Email Us.
Oct 29, 2022 • Watches
I was given a Lucien Piccard womens vintage gold tone watch. Iam unable to find a model or serial number on the back casing or sides.
I got this Lucien Piccard gold watch in a vintage shop with no model/serial number anywhere. Can someone identify if it's real LP or a replica?
I have a lucien piccard watch, purchased probably in the 70's. Would it be water resistant?
Yes, I think that your Lucien Piccard Watch is water resistant until now as long that the gasket of the caseback is still intact. and for you to find out that the gasket of your watch is still intact then, you should bring your watch to the expert to check your watch gasket. i hope i solve your problem.
Looking for a leather band for a lucien piccard
i only found some for women sorry !!! http://www.newegg.com/Product/Product.aspx?Item=9SIA01C0001NU2&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Watches-_-Lucien+Piccard-_-9SIA01C0001NU2
How to size a lucien piccard mens watch bracelet - model 26932wh
mcdevito75 here, Best bet, look for a small watch repair shop in your area to help fit your watch and to save on the cost.
Need New Watch Band
Top Lucien Piccard Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Lucien Piccard Watch Expert? Answer questions, earn points and help others
