LG Optimus Black Smartphone Logo
A
Anonymous Posted on Jul 29, 2015
L-FIX my LGOPTIMUS cell phone
Cannot get any screen but to dial an emergency number.I never had one
1 Related Answer
Anonymous
  • Posted on Feb 22, 2013
SOURCE: i forgot my emergency number and my password for my LG cell phone How do i reset my phone completely
You go to your google account and should be able to it that way
Need to know what the emergency setting is and when would it be used
If I understand your question, do you mean the 'Lock-Screen' emergency call numbers?
These are your local emergency services numbers such as 911,
police, ambulance, and I think your SP free-dial nos as well.
Your SP in your location can give specific numbers for your area.
Nov 21, 2017 • Cell Phones
When I dial a local number my phone says too dial an emergency number only.
sounds like the phone may be in emergency mode. try turning phone off and remove the battery for a few minutes. put battery back in and restart phone.should be back to normal.
Feb 06, 2016 • Cell Phones
I am changing from tmobile LGOptimus. Tmobileservice . To Striaght Talk service with ths same LGOptimus phone what is the correct APN settings??
Hello, You will have to talk with straight talk tech support to see if possible and get the correct apn settings. Here is the website for the number you need. 1-877-430-2355
Contact Us Support Phone Number StraightTalk Wireless
Oct 25, 2015 • Cell Phones
How to get a boost max phone out of emergency call mode
EMERGENCY CALLS
Emergency calls can be made in all device conditions as long as there is any
available network signal. From locked screen conditions press the Emergency
Call button to open the dialler, then dial 000 and press the handset icon to
make the call. In all other conditions press the Home key to return to the
home screen then press the handset icon to open the dialler. Enter the
Emergency number (000 or 112) and press the handset icon to make the call.
Aug 13, 2014 • Cell Phones
6helpful
3answers
How to fix my nokia 2730c-1 white screen
hi ,
replace your LCD is the best solution to your problem...but before you do that ,test your phone like this maybe its software problem...dial 112 or any emergency number in your location...if you hear a voice of a operator its is lcd problem ...but if you wont connect to the operator or you hear nothing its LCD or display problem...
Why won't my lgoptimus gt540 don't save the text msg center no
If doing the *#*#4636*#*# and the SMSC number wont install.....giving you an "install failure" note. And you try a full phone reset....it's an Android software issue.
Had to return a GT540 this weekend after trying everything with the technical guy at Vodaphone.
When my mobile is in my bag, it dials random numbers caused by items in my bag pressing against the phone. How can i stop this from happening.The message emergency call 'yes or no' appears.
You can have the keypad locked by opening the menu and setting in phone settings the time requried to lock the key pad. so after using the pad locks and will not dial any numbers.
the calls to emergency is because of this being active.
Screen not working
hi,
have you tried to dial 112 or 117?or depends on the emergency number in your country ,if you dial that and you hear something from operator the problem of your phone is the glass display or LCD...try to press this simultenously ,*# power on ,and there is a bootmode that appear ,your phone needs to reprogram,,better go to a nokia specialist to diagnosed your phone..i hope it will help ,thank you
2helpful
I can turn it on.
try to dial emergency number,,if there is an voice from operator,,it means your phone is working with white screen display,,.you have to replace LCD. but if you dial emergency number,,and there is no voice..it means you need to reprogram your phone
21helpful
4answers
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
