Question about 3Com Home Connect Lite Webcam
What is f6 and how can i fix it - 3Com Home Connect Lite Webcam
My hotpoint Aqualtis has an f6 code displaying.. Any ideas on what the problem is and how to fix please?
Hi!
F6 means:
- Broken buttons;
- A faulty electrician between the control board and the controller;
- Faulty electronic module
Mar 05, 2017 | Hotpoint Washing Machines
F6 error code of lg split ac
http://www.fixya.com/support/t4357840-onida_split_ac_displays_f5_f6_error
People have answered this question on here so thought this would help.
F6 error is related with the indoor blower motor check the return signal wire of motor with the small connector and fix it properly.
Dec 24, 2016 | LG Heating & Cooling
What is f6 and how to fix it
F6 is a function key on your keyboard that will only do what it is surposed to if the systemboard drivers are installed.
Jul 29, 2015 | Computers & Internet
Im getting a f6 code on my digital control topside pack. what is this and how can i fix it
F6 typically doesnt indicate an error. This is usually a programming code that tells you spa to filter every 12 hours.
If it is a FLo code that just looks like an F6, then you need to either replace the filter, replace the flow switch , or make sure the pump is pushing enough water.
Mar 18, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
How do i fix f6
Stk 470-040 ic is blown and need to be replaced at service cntr.
Jul 25, 2010 | Panasonic SC-AK78 CD Shelf System
Mine keeps giving me a F6 error, any ideas
F6 is a communication error. It is either a loose connection to the control board, or the control board is shot. They should have diagnosed this when they came out to fix it. Open it up, and look for loose connections.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
F6 code// will not finish spin cycle every time?
Mar 25, 2009 | Kenmore Elite 45986 Front Load Washer
Acer aspire1690
Your screen sounds fine, most likely just your backlight going out, either that or you could have hit the key for using an external monitor (function f6 is the LCD/external monitor switch for my computer). I'd look into the function f6 and play around with that, if not you can just buy a new backlight from ebay or an internet supplier.
Jan 21, 2009 | Acer Aspire 1690 Notebook
Kenmore Microwave hood combo Model # 66569689992 F6 error code?
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Dec 08, 2007 | Microwave Ovens
3Com Home Connect Lite Webcam Logo
85 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
