SOURCE: hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
SOURCE: hp ml350 g3 how can i install window xp on it and
The problem you will have is with the RAID drivers as HP does not support running XP on this box. You can try to load these using the F6 option during the XP installation but no promises that it will work. Try using a Server 2000 or 2003 driver.
You may get lucky and be able to find an XP driver for the specific SCSI chip set used on your controller. If so, then you should have no problems.
SOURCE: HP Proliant ML 370 G3 the server is got hung
Check if the processor fan is running properly. Also check the RAM modules, as these could sometime cause the machine to hang.
SOURCE: ProLiant ML110 Server: i NEED WINDOWS XP dRIVERS FOR HP PROLIANT G3...
Why the Machine is not ment to use as Desktop try using windows 2003 server driver from cd supplied with it that will work for xp
SOURCE: I want to install windows
1. turn the server on, when you see the smart array controller posting
hit f8 to enter the controller settings, here create the array (1, 5,0)
2. insert the windows cd and follow the normal installation procedure
or download the smart start cd from here for a guided installation
with SSCD just insert the cd and follow the directions
