We have two of these ranges and one has had oven problems.It used to start up then shut down after about 10 minutes. We have replaced the control valve and thermostat. And now it heats up and stays on but just keeps getting hotter and hotter. We are on a remote island in Alaska and our appliance repair guy says there is nothing else to fix
Any ideas
Let me see if I am understanding you. The oven used to heat up and then shut down after 10 minutes. then you had a guy replace the valve and thermostat on the same oven, and now it will not shut off at all? I think maybe your repair guy connected something wrong. if you have 2 of these same ovens, visually check the one that works against the one that don't, see if there are any differences.
I should have described it better, for about a month it would turn off after we lit the pilot, then one day the pilot stayed on so we cooked an egg dish in it at 450 and then turned it down to keep something warm and the oven never went down. The repairman replaced the control valve and said it worked. We think he didn't stay long enough turned it on it stayed on, then turned it down and the flame went lower so he assumed it worked. However it just keeps heating up, it goes down for a bit then up and stays high. So he replaced the thermostat and that didn't solve the problem. He says that is all there is to fix on the stove.
