I am trying to change my NAT settings from strict to open so that I can play Xbox Live more efficiently, but I only want to change this on my xbox and not on my computer. Help? i need to change my NAT from strict to open to play X-box live
The ports should be opened only in the router not in the x.box, go to a working pc..
To
allow traffic from the internet to enter your local network, you will
need to open up ports or the router will block the request.
Because our routers use NAT (Network Address Translation), you
can only open a specific port or ports to one computer at a time. For
example: If you have 2 web servers on your network, you cannot open
port 80 to both computers. You will need to configure 1 of the web
servers to use port 81. Now you can open port 80 to the first computer
and then open port 81 to the other computer.
Step 1 Open your web browser and enter the IP address of your
D-Link router (192.168.0.1). Enter username (admin) and your password
(blank by default).
Step 2 Click on the Advanced tab at the top and then click Virtual Server on the left side.
Step 3 Check Enabled to activate entry.
Step 4 Enter a name for your virtual server entry.
Step 5 Next to Private IP, enter the IP address of the computer on your local network that you want to allow the incoming service to.
Step 6 Choose Protocol Type - either TCP, UDP, or both. If you are not sure, select both.
Step 7 Enter the port information next to Private Port and Public Port.
The private and public ports are usually the same. The public port is
the port seen from the WAN side, and the private port is the port being
used by the application on the computer within your local network.
Step 8 Enter the Schedule information.
Step 9 Click Apply and then click Continue.
SOURCE: Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
i have the same problem, ive looked at the thread its the same as myne but when i go on the virtual servers it doesnt say discription or imbound port it just says lan port publick port i dont understand :(
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect...
Kudos! Thanks!
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
I am using a Dell truemobile 2300 wireless router and its doesn't let me play xbox live.
i have the same problemmm helppp
