Question about Nortel LG-IP Phone 8830 VoIP phone
DCOB Flaut, Small call centre, 10 lines all down.
    Top Expert:
  • Nortel Master
  • 64,268 Answers
Contact the service provider .
Posted on Jul 28, 2015
SOURCE:
Relisys tv model no rp4207b ru black line down centre
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 25, 2015 | Relisys Televison & Video
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
Jun 08, 2014 | Samsung Televison & Video
Need to make hole bigger on a 45 record
I am aware of jukebox mechanisms that would clamp down on the record, and if it detected a small-hole in the 7" disk, it would change the RPM to 33 1/3, and the large hole would mean 45 RPM.
However, if we drill down into the history of the development of the 45, we can see that it was developed as a replacement for the 10" 78 RPM disk. It was also intended to be played on a distinct 45 RPM player, and thus the large hole to discourage use on regular turntables.
Most of the 45s in the UK had a pushout centre (some round, some triangular). 33s didn't have this. Ex-jukebox records had the pushout pushed out, and clip-in new centres could be fitted
Mar 16, 2010 | Audio Players & Recorders
Centre pole is failing to hold tent up in any real wind
TRY DRILLING A SMALL HOLE ON THE INNER POLE SLIGHTLY SMALLER THAN THE DIAMETER OF THE SCREW. U WILL WANT TO DRILL SMALL HOELS EVERY FEW INCHES(CM) SO THAT U WILL BE ABLE TO SET THE POLE AT VARIOUS HEIGHTS IN THE FUTURE.
Jan 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
Black line down the centre
please click here and follow the instructions to resolve the issue.
May 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Fine line down centre of screen
call Toshiba ASAP if you still have warranty, the TV needs to be replaced. The line will get worse!!
Feb 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
1996 DT 200 R TURBO TUNE UP
not sure if u have tried this my friend,, but on the fly wheel side of the bike,, or left of the bike as u r sat on it,,is the casing covering the fly wheel,, on that casing u will see a screw ,ie looks like a nut ,, undo that to reveal in the hole a little bit of the fly wheel,, shine a torch down it and turn the engine over by hand or put it gear and rock it ,so the fly wheel turns eventually u will see a tdc mark or line engraved on the wheel,, ,,in the hole u r lookin down will be a pointer or small arrow on the casing,, line the to up ,,and then take the spark plug out and just lightly put a screw driver down the hole of the cylinder, it should be at the top of its stroke,,turn the engine over once to make sure the piston is as top dead centre,and the mark on fly wheel line up,, if u r using a strobe light it will be 10% b4 top dead centre.. any probs ,,e mail me, 4 the other solution,, deeptattoo@hotmail.co.uk
Dec 20, 2008 | 2006 Yamaha DT 125 X
TV will not turn on
check the resistors and capacitors in vertical section of the television..or change the vertical ic.
Dec 29, 2007 | Televison & Video
Nortel LG-IP Phone 8830 VoIP phone Logo
878 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Sanjaya Sahu
Sanjaya Sahu
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
