Question about Samsung Refrigerators
HOw can I repair the Samsung French Door fridge which has a broken handle on the freezer. side) that connects the handle to the actual freezer door that is broken.
The plastic part that the freezer handle that attaches to the freezer is broken on the right hand side. Samsung no longer carries the part. I bought this unit in about April of 2011. Samsung refuses to do anything to help with this and the extended warranty does not cover the handle door. Help!!!
  • Lynda Nichols
    Lynda Nichols Jul 28, 2015
    Did the above question make any sense? Do I need to clarify the information??
    Top Expert:
  • Samsung Master
  • 10,875 Answers
Well,you neglected telling us what the fridge is,couldve found the part on ebay,now you can
Posted on Jul 28, 2015
SOURCE:
How to remove the bottom freezer door handle on Samsung French door refrigerator model # RF26XAERS
The screw heads may be inside the door cavity, screwed into the back of the handles.
If this is the case, as with our Fridge-Master fridge/freezer, it is very difficult, needing strip down of door.
Good luck... :)
Jun 06, 2018 | Samsung Refrigerators
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
Samsung French door fridge freezer handle came loose. The ***** on the right side fell into the back of the handle attachment so it won't go flush with the fridge.
Hello Marilyn;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the inside liner of your fresh food section.
Usually the door handles are held on in one of two ways.
1.) Inspect the sides of the door handles. Are there small allen wrench screws - tighten them.
2.) Ok, no screws on the side. There are mounting brackets screwed onto the door. At times the screws become loose. Use a little muscle and pull the handle up hard to release from the bracket. Tighten the screws on the bracket to the door. Position the handle back on the bracket and pull the handle down hard until secure.
Mar 03, 2016 | Samsung Refrigerators
My freezer door handle has come away at the top how can i fix it mysel
If handle is broken get a new one and by removing inner door panel install the new one. Parts available at attached link Search Over 2 1 Million Appliance Parts
Mar 02, 2016 | Samsung RSA1SHPN American Platinum Inox...
GE Energy Star French Door Bottom Freezer handle popped off
You cant find a hole to insert screw from outside. It is true, and you can't fix it yourself to what it looked like earlier. The company first screws in through the handle and then covers the hole made by it with the material of the handle. If you have to fix it yourself, you can only pierce those screws through the handle leaving the mark behind. If you don't want that, contact your company or dealer.
Apr 22, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Feb 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
345 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
