FoodSaver V3230 Logo
Ardis Beach Posted on Jul 27, 2015
Trying to vacuum and seal the broccoli after blanching, cooling and letting it drain. It won't seal the bags. It vacuums the liquid til the tray fills, then shuts off. I start over. How to fix this?
I have wasted quit a bit of the bags because the food saver is not sealing completely. It leaves a 1/4 to a 1/2 inch unsealed therefore I can not vacuum seal. What am I doing wrong
Try making a seal with nothing liquid in bag, check seal on bag after. If seal looks good it could just be liquid getting on seal area causing it not to seal. There are tips online on how to help prevent this (example: placing rolled up paper towel sheet). If seal still looks bad than you may have a bad spot on the heat seal wire.
Jan 23, 2016 • Vacuums
Why my foos saver is not sealing
I've found with mine I have to hold down firmly on the top while unit is heating the bag to seal it. I continue to hold the lid down for about 10 seconds after heating stops until the seal cools. Hope this helps.
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
1helpful
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 • Vacuums
1helpful
2answers
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
1helpful
I purchased a Seal-A-Meal roll to make my own bags but can't figure out how to use it. I have a model VS108. Is it possible to seal without vacuuming?
On most models of vacuum sealing systems, you cut off the roll the size of bag you need. Slip one open end of the bag just on top of the heating element over it about 1/8-1/4" and press down the lid to seal the bottom of the bag. Fill the bag and then place the open end far enough into the vacuum cavity over the heating element and close the lid and press down and hold until the cycle finishes. If you don't want a vacuum, just put enough bag material to cover the heating element but not into the vacuum cavity. Hope this helps
Jan 03, 2011 • Vacuums
1helpful
How do you get the cover off the vacuum so i can have access to the motor?
If you are trying to get to the motor and not the bag Sears repair people have a special tool to remove the rubber seal and if you try it your self you will end uo ruining it or stretching it and if it does go back together when your done it wont seal properly and therefore it wont have sufficient air flow.
4helpful
3answers
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 • Vacuums
Top FoodSaver Vacuums Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Curt mueller
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
