LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Logo
Nicolai Hel Posted on Jul 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pwr won't stay on. after power button in pushed power immediately turns off. Suspect control board fuse or relay issue. Have tried reset. CBoard is effectively unavailable.
I'm hoping this is just a fuse or relay issue and not a control board issue. If that is the case, then the washer/dryer unit is toast. Holding the power button in keeps power on...until released Please help!
johnny rebel
Level 3:
Top Expert:
  • LG Master 10,875 Answers
  • Posted on Jul 27, 2015
 johnny rebel
LG Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2939663
Points
47944
Testimonial: "I was told that the "C" model of this control board was incompatible with this model. It must be the "E" model board. If you have additional information regarding verified compatibility, I'd be very interested."
  • 6 more comments
  • Nicolai Hel
    Nicolai Hel Jul 28, 2015
  •  johnny rebel
    johnny rebel Jul 28, 2015
    read where it says this part is compatible with your machine,,http://www.repairclinic.com/Shop-For-Par...
  • Nicolai Hel
    This is a link to the "C" board however I see no reference to it being a replacement for or being compatible with, the WM3677HW. Your search query is for a WM2277HW w/c is not the model I have. If there is a direct reference to this "C" board being interchangeable with the "E" board, I'm not seeing it...although I would very much like to!
  •  johnny rebel
    you r right,it was looking for the wrong part,it is not available,but,yours is fixable,here r the linkshttp://generaltimerepairs.com/
  •  johnny rebel
    http://www.remanufacturedapplianceparts....
  •  johnny rebel
    http://www.corecentricsolutions.com/publ...
  •  johnny rebel
    http://www.repairclinic.com/PartDetail/b...
  •  johnny rebel
    out of stock,means alot of them are bad,consider getting different machines
2helpful
2answers
Nothing works Passenger door . 2003 GMC Sierra. no mirror, PL or window.checked fuses.tried new controls. I utubed a guy said disconnect battery ground , will reset .I did and worked.until I moved it.
Power windows don't use fuse's , has circuit breakers
• PWR WDO CB 25A (fuse block) (System power for left and right windows 2-door vehicles. System power for LF and LR windows 4-door vehicles)
• PWR WDO CB 25A (IP wiring harness junction block) (System power for RF and RR windows 4-door vehicles)
Door Lock System Components
The power door lock system consists of the following components:
• The driver door module (DDM)
• The passenger door module (PDM)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock switch
• The door lock relay
• The door unlock relay
• The liftgate lock relay--utility vehicles with liftgate only
• The reversible door lock actuators in each of the doors and liftgate
• LOCKS 20A fuse (rear lock/unlock relay supply voltage)
• ECC 10A fuse (liftgate lock relay supply voltage)
2answers
On 2004 pontiac montana what does fuse 7 control
7-BATT MAIN 1
60A
Fuses: •
CIGAR/DLC/APO FRT
• CLUSTER BATT
• CTSY LAMP
• ON STAR
• PWR LOCK
• PWR MIRROR
• RAP RELAY
• RR PWR SCKT
look below for above listed componet's , pull those fuse's one at a time till arc stop's ,then you found your problem circuit . Do you know where the I/P fuse box is ?
Fuse Block- I/P
Right side of the I/P, in the right front door opening
Fuse Block-I/P Label
Fuse Block-I/P Application Table Fuse/Circuit Breaker
Rating
Description
BCM PRGRM
10A
Body Control Module (BCM)
ENHANCED EVAP/AWD
15A
Evaporative Emission (EVAP) Canister Vent Solenoid, Clutch Pump Check Valve
CIGAR/DLC/APO FRT
20A
Auxiliary Power Outlet-Front, Cigar Lighter, Data Link Connector (DLC)
CLUSTER/BATT
10A
Instrument Panel Cluster (IPC)
CRUISE
10A
Cruise Control Module (CCM), Cruise Control Release Switch, Cruise Control ON/OFF Switch
CTSY LAMP
10A
DRL
10A
Daytime Running Lamps (DRL) Control Module
HVAC/DIC/DRL/HEATED SEAT
10A
Air Temperature Actuator-Left, Air Temperature Actuator-Right, Daytime Running Lamps (DRL) Control Module, Driver Information Center (DIC), Mode Actuator, Rear Window Wiper/Washer and Multifunction Switch (Heated Seat Switch), Recirculation Actuator, Relay Block (Rear Window Defogger Relay)
ELC/TRAILER
25A
Auto Level Control (ALC) Air Compressor, Auto Level Control (ALC) Air Inflator Relay, Auto Level Control (ALC) Sensor
FRT HVAC HI BLWR
30A
Blower Motor Resistor Assembly
FRT WPR/WSHR
25A
Windshield Wiper Motor, Windshield Wiper/Washer Switch
HAZARD
15A
Turn Signal/Multifunction Switch
HEADLAMP
20A
Daytime Running Lamps (DRL) Control Module, Headlamp Dimmer Switch, Headlamp Switch
HTD MIRROR
10A
Outside Rearview Mirrors-Left, Right
HVAC/BLOWER
25A
HVAC Control Module
IGN1
10A
Body Control Module (BCM), Instrument Panel Cluster (IPC), Left Rear Side Door Actuator Control Module, Rear Object Sensor Control Module, Right Rear Side Door Actuator Control Module, Stop Lamp Switch
LH HEADLP HIGH
10A
Headlamp High Beam-Left
LH HEADLP LOW
10A
Headlamp Low Beam-Left
LH T/LP
10A
Tail Lamp-Left, Trailer Rear Wiring Harness
MALL/CLUSTER
10A
ON STAR
5A
Vehicle Interface Unit (VIU)
PASS KEY
10A
Theft Deterrent Control Module
PCM/ABS
10A
Electronic Brake Control Module (EBCM), Fuse Block-Underhood, Powertrain Control Module (PCM), Park/Neutral Position (PNP) Switch
PCM/CRANK
10A
PCM/PASS KEY/CLUSTER
10A
Instrument Panel Cluster (IPC), Powertrain Control Module (PCM), Theft Deterrent Control Module, Instrument Panel Cluster (IPC), Powertrain Control Module (PCM)
PWR LOCK
20A
PWR MIRROR
10A
Outside Rearview Mirror Switch
PWR QTR VENT
10A
Auto Level Control (ALC) Air Compressor, Auto Level Control (ALC) Sensor, Rear Quarter Window Switch
PWR/HEATED SEAT PSD
30A
Driver Seat Assembly, Passenger Seat Assembly
PWR SLDG DR
30A
Left Rear Side Door Actuator Control Module, Right Rear Side Door Actuator Control Module
PWR WDO
30A
Window Switch-Driver, Window Switch-Front Passenger
RAP RELAY
10A
Relay Block (RAP Relay)
RH HEADLP HIGH
10A
Headlamp High Beam-Right
RH HEADLP LOW
10A
Headlamp Low Beam-Right
RR HVAC/TEMP CONT
25A
Air Temperature Actuator-Auxiliary, Blower Motor-Auxiliary, Blower Motor Relay-Auxiliary, HVAC Control Assembly-Auxiliary, Mode Actuator-Auxiliary
RR DEFOG/ HTD MIRROR
30A
Window Defogger Relay-Rear
RR FOG LP
10A
Fog Lamp Relay-Rear
RR PWR SCKT
20A
Auxiliary Power Outlet-Rear
RH T/LP
10A
Tail Lamp-Right, Trailer Rear Wiring Harness
RR WPR/WSHR
20A
Window Wiper Motor-Rear, Rear Window Wiper/Washer and Multifunction Switch
SIR
15A
Inflatable Restraint Sensing and Diagnostic Module (SDM)
STOP LAMP
15A
Stop Lamp Switch
SWC BACKLIGHT
2A
Steering Wheel Controls-Left, Right
T/SIG
10A
Turn Signal Switch and Backup Lamp Relay
Hitachi 65SWX20B no picture/sound, 4 out of 5 green LEDs on, red LEDs on, green B+ LED is off. Pwr Relay clicks on, TV only turns on/off. IP02 location/How to check for 14-20V on terminal 4 of IP02?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
After reading several forums when my LG 42PC3D died, I went in thinking I had the answer. It would turn on, but then off immediately. The Y-sus board had a blown fuse. I didn't want to risk frying...
Y and X-sus boards should be replaced at the same time due to they way they communicate with eachother. I suspect that the x-sus is also faulty.
Thank you!
My Jandy rs all button says the pump is off but the pump stays on. This has happened before and it seems to reset its self or after i turn the pump breaker off it resets. What is going on?
Very odd.
I would suspect a bad relay.
Go to the outside power center located at the equipment. Press the mode button until the "Service" light is on. Now press the filter pump button. Turn it off and on several times to make sure the relay is working correctly. If not, replace the relay.
If this is not the problem then I would reset the board at the power center by pressing the recessed "Reset" button with the tip of a pencil or pen.
If this does not work, you could call Jandy and have them flash your board with the newest software.
1helpful
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
1helpful
Will not power on-- batteries are new- if pwr
Hi:
I was using one of these for the last 8 months, and mine did the same thing, I would push power and the unit will just blink the lights then shut off, But if I hold the power button the light will stay on until the button was released, so I contacted Solo Tech support and they told me the system control board was bad, and in order to get a new board I had to be an authorized servicer for then, I found the board online and the price for the board exceded the price I paid for it. So i deemed it necessary to just purchase a new Scanner....
1helpful
2answers
The 4 wheel drive doesn't work in my 89 Ford Bronco
The sound is not coming from the glove compartment, it is coming from the panel behind the drivers seat, that's where the relays and computer are located.
The relays click and apply power to a transfer case motor.
The motor attempts to turn a shaft that engages the front drive shaft.
When the computer thinks the shaft has NOT turned it tries again.
It will try three times then quit, figuring the shaft has not turned.
Get someone to crawl under the vehicle and engage the 4WD (just turn on the ignition- do not start the engine) See if they can hear the motor attempt to turn the shaft, it will make a clicking sound.
If not the connections or the motor may be bad.
I have found the most probable cause is the relays on the control board.
If you are technically adept --
you can remove the small side panel from behind the drivers seat and remove the control board. (remove the power plugs first)
Clean the relay contacts and bend them a little to give them more 'wipe' to keep them clean longer.
Put it back in and turn on the ignition.
Then push the RESET button on the side of the board.
Try the in / out 4WD a couple of times. If it doesn't work turn off the ignition, turn it back on and push the reset button again.
Wont power up.
My guess is in the desoldering-resoldering process...try to get back to every resoldered part you did. Be sure you returned the connectors to their proper terminals.
If you can trace the output circuit before the protection circuitry...try to get a near zero voltage. Any DC voltage appearing will trigger the protection - thus indicates red.
what else did I miss?...yeah! goodluck!
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
