I'm hoping this is just a fuse or relay issue and not a control board issue. If that is the case, then the washer/dryer unit is toast. Holding the power button in keeps power on...until released Please help!
SOURCE: LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
turned out to be the control board and the transformer - an expensive fix!
SOURCE: LGWM2277H LE light came on does the motor have a reset button i need to push
Hello momof3611
Welcome,
You said, Your LGWM2277H washer LE light flashes. Troubleshooting guide says overload
in motor. Is there a reset on the motor that needs reset or does
something else need done. washer was working fine until we put a big
load of jeans in to wash. when we checked wash soapy water was in
washer and I can't get it to rinse. drum is not turning.
If you overload, with to much clothes the weight will trigger this error your having in most washer.
Take some clothes out.
Then try this:
Unplug the washer for 5 minutes, or if you can't reach the plug, turn the breaker off for 5 minutes and then the system should reset itself!
Let me know.I'm looking right now for any reset code in the repair manual too!
Huuum
Please remember to leave a rating.
SOURCE: LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
SOURCE: LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
SOURCE: LG WM3001HPA Washer interior light is on but will not power up
Door close interlock switch is out of adjustment. Remove side panel(s) and adjust it back to a point where it recognizzzzzzzzzes it closed. Bolt eveything back to gether and you be done!
