Tilia FoodSaver V2240 Logo
Why does the red light stay on even though the tray is empty and clean?
My tray is empty and clean but empty tray keeps coming up
Hi Shoba
Photo sensor or switch is blocked.
Not sure if yours is an Infra Red beam or switch
Clean & inspect with flashlight
Look for light path (blocked) or moveable part (switch)
Actually.... it must use an Infrared Light Emmiter to shine through the grounds holder to the sensor on the other side/
10 Minute Fix.... I hope
tip
EMPTY TRAYS!!
This just came up on our Thermador Savor built in coffee maker. I put descale in tank but accidentally pushed Clean button, rather than Calcif!! So I hit the off button...but it stayed lit green...and EMPTY TRAYS would not stop!! The trays were empty!! And I could not hit the on off button...it stayed lit green and EMPTY TRAYS continued. I had rinsed contacts, even. I can't find original answer in here right now...but I thoroughly wiped the contacts that are in the back of the tray...but there are contacts in the "front" as well. DUH! They are on the sides of front of tray. Wiped them down..lo and behold, EMPTY TRAYS went away, and now I am descaling the machine!! Oh, I also do the clean/calcif myself monthly, and I don't wait for the machine to tell me! I received this advice from foxy also. Life is good again!! Thanks FIXYA!!
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Braun 8995 - YELLOW LIGHT STAYS ON!
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
1helpful
Red Light 28 is flashing even when dregs are emptied
Check the edge of the container that goes in to the machine there is a small part that sticks out, it is possible that that piece is not touching the microswitch in the machine. Remove the drain tray and the dregs tray, check the corners of the machine for loose coffee grounds.
Is this thing working?
I had the same problem...I was going to get rid of the unit...I notice that tha red light on the little screen on the top was on...then I closed the tray (all this time I though it was closed) all the way and the red light went off and the unit started cooling! I hope this may help you.
Dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
2helpful
5answers
Problem with Benvenuto B30 cleaning
After I cleaned the tabs really well, I still had the same problem. So, I took the back off so I could get to the "switches" that close the feedback circuits for the "Trays Missing" and "Clean Trays" messages. Long story short, you DON'T need to take the back off. You can solve the problem if you remove the trays and carefully remove the right side metal tab. This will stop the false readings, at least it did for me. Save the tab if for some reason you need to it later.
To remove the right side tab, use something like an eye glass screwdriver or butter knife to pry it up and out of the two small holding tabs. Then rotate the metal tab up and away from the tray and it will fall right off. Pictures below. a9c5bc58-d1a4-488c-891c-2b50084d4d96.jpg 3a317125-915d-4f72-a472-8ae2ea938a3a.jpg 383c8eeb-4d14-467d-842b-ea47d989e30b.jpg bd453672-83d3-46db-8ab5-d9cac5576ad8.jpg da367966-03c1-462d-961c-c5a9605fe4f4.jpg
Top Tilia Kitchen Appliances - Others Experts
john h
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
