Voicemail help with new phone. When you press VMAIL, it won't let you program it. It plays the message to LEAVE a VM with the corresponding person.
SOURCE: Panasonic KX-T7453
If there is a voice mail button on the other set/s, press it, then [#][6], then [*] and your mailbox number.
If there is no button, press [intercom] 165, [#][6], [*] and your maibox number.
Note that 165 is a common voice mail extention number, but it may vary from site to site.
SOURCE: panasonic kx-t7453, night mode message programming
Do you mean have calls transferred to voice mail? Go into system programming and change 408 (DIL 1:1 Nite) to point to the ext of the voice mail port, which depends on your system. That number is found in 118
SOURCE: Phone is Panasonic KX-T7453, previous
The override comes from the Voice Mail System owner logging into mailbox 999 and resetting the extension password.
Carl
SOURCE: If I call an extension
Press the MESSAGE button. It will light the lamp on the receiving station and when they press MESSAGE it will show that you called.
If you're trying to program "voice mail", then there are specific instructions to setting Call Forward No Answer or just dialing into the VM sytsem and dialing #6 and their extension to leave a direct message.
Carl
SOURCE: panasonic kx-t7453 corded digital super
Pretty much, it depends on what happens when you dial 165. That's the voice mail access number for a Panasonic TD phone system with Pana VM. If you get the voice mail lady, set the box up and then from the intercom dial 7102/3/4/5 where 2 is all/3 is busy, 4 is no answer and 5 is busy/no answer and 165 or whatever the VM access number is and possibly # (I forget if it's required). That will light the FWD/DND light and send calls to the voice mail system.
Carl
