What you refer to as the "circle" is most likely the low voltage battery symbol and flashing means to change the batteries. The wrench means fault which just goes along with changing the batteries.
It means that the airbag system has detected an electrical problem and may not work properly in an accident. The same light will flash if an airbag-less aftermarket steering wheel is installed unless a special kit is installed to eliminate the flash.
Your version has a Dynamic Controls model controller and joystick. Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand) Turn the chair off, wait 5 seconds, turn the chair back. If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors. 3=Left motor fault 4=Right motor fault 5=Left brake fault (may not be engaged) 6=Right brake fault (may not be engaged) Any other fault code usually means the electronics or wiring is bad and not worth fixing.
