Heating & Cooling Logo
Abusalam Shaikh Posted on Jul 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I set my remote for cold - Fujitsu Heating & Cooling
coolworks
Level 2:
Scholar:
  • Expert 158 Answers
  • Posted on Aug 04, 2015
coolworks
Expert
Level 2:
Scholar:
Answers
158
Questions
0
Helped
227566
Points
223
Press the 'mode' button on your remote until it says 'cool' or shows a snowflake symbol. Careful that you don't set it to 'heat' mode accidentally if it only has symbols. The 'sun' (heat) mode symbol can look like a snowflake on some of these remotes. Then set the temperature to suit you.
1helpful
2answers
Unitherm air conditioner remote skips the heat mode
Halo
Remove your battery's for at least for 10 sec and reset the remote if still the same problem then you should replace it just be sure that the universal remote is compatible with your unit.
regards
1helpful
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Colde list 3301b01 unvisal
0382,0388,0380. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
There no heat coming from AC, just cold air
The control looks set to 21 C. At this setting only cold air will flow. Please set the air temp to 28+ for the hot air to flow.
1helpful
Air conditioning unit is not responding to the remote
If you can't change the settings manually, then the control pad is bad. If you can and the remote won't change the temp or mode then the remote is bad and will need to be replaced.
3helpful
2answers
2answers
Remote Start doesn't work
manually lock the door with the key this may reset the alarm
Hi i have a cs-w24ekr air conditioner. The problem is it blow's cold air when set to heat even at 28degrees.
you have pressed the mode button on remote until it has said heat aswell? becasue 28 degrees in cool mode will still seem cold unless the mode is also set to heat.
Top Fujitsu Heating & Cooling Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
