Question about Hotpoint Hot Point RGB745DEPWH Gas Ranges
I have a hot point washing machine and at the end of every cycle it's showing error code F - 01 and door won't open and its started to smell of burning
    New Friend:
  • 111 Answers
Fo1 mean control board is hot electronic circuit board fault
A quick fix is to uplg the unit for2 minutes (Irecommend10 minutes) then plug it in and wait a minute try to operate it
Posted on Jul 26, 2015
SOURCE:
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Replaced CCU, Sears washer still will not run
Suggestion: Unplug washer from mains. Open up the machine, disconnect and refit all connectors with wires one by one. Could be some loose connection somewhere. Also helps in the long run
Click if helped.
Mar 29, 2013 | Washing Machines
The door is opening even when the machine is on.Error code 50 comes on display
It ispossible that the error comes because the door was opened during the cycle. Remove power for sometime to reset . Now check the door lock and safety on feature while the cycle starts. If there is fault in this link the program will show an error.
Check the lock : http://www.espares.co.uk/advice/washing-machines/a/7/1207/how-to-replace-a-washing-machine-tumble-dryer.html
Jun 28, 2012 | Washing Machines
Our washing machine smells at the start of a wash cycle and smells of fish.We have done ample clean cycles using different products and washed using various washing powders and liquids etc at 90+c. is...
posibly not melting glue as there not used in making the machine try putting a blech hot water wash cycle a few times in the machine and if the washer is not being used leve the door open to allow the unit to breath and stop using powder wash detergent use liquid wash detergent
best luck
Nov 10, 2010 | Bosch Washing Machines
Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Oct 08, 2008 | Neff W4380X1 Front Load Washer
Error code F-01
Press "end of cycle button" for over 5 seconds, it will unlock. Note: the door should be opened only on hearing a click, or wait for 2 minutes after the wash completes.
I need a rating please, dont forget(!)
Dec 27, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Hot Point RGB745DEPWH Gas Ranges Logo
151 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
