Sigma Bc 906 Computer Logo
Jerrold Pfrimmer Posted on Jul 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wheel size 559x22mm no manual to help calculate
Bill Boyd
Level 3:
Top Expert:
  • Master 53,816 Answers
  • Posted on Jul 26, 2015
Bill Boyd
Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925673
Points
172802
To calculate anything you need to know the dimensions
what is 559 measurement is it the width,diameter,radius,circumference
and the same for the 22
Then what are you trying to calculate
ask the question again with all the details and you may get an answer
3helpful
What is result of tire size setting of 2.224 versus 2.233
The calculated size is more accurate, whereas the manual suggests a setting. If you cannot set the size accurately then use the suggested setting.
What do I set my sigma BC506 wheel size setting to? It appears that the wheel size chart is incorrect. My tire size is 26x1.95 Thank you
If you really care about accuracy calculate it yourself (A) or roll it out, measure the distance (B) and set that according to the manual on the same page as the chart.
http://www.sigmasport.com/en/service_center/produkt_support/bikecomputer/
3answers
I do not have a operation and setting maual for my Cannon p23-dh V desk top printer/calculator. Please send me a copy. [email protected]
Hi and welcome to FixYa
Here is the official website with your product manual, there you can find the user guide manual among other manuals, just click on the link and download it, size is around 15MB.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Hope this information was helpful
Sincerely,
aDynamite.
9helpful
How do I calculate wheel size for my bike. 25 inch wheel without tire for example
There's a size chart on page 15 of the manual that has great instructions for measuring and entering the wheel size.
You can get the manual from Sigma's website at this link.
Method "B" is the most accurate way -- make a chalk mark on the tire and stand the bike up next to a wall with the chalk mark at the bottom.
Have a friend make a chalk mark on the ground at that point.
WITH YOUR FULL WEIGHT ON THE BIKE, move forward for one rotation of the wheel -- until the chalk mark is on the bottom again. Do this as straight-line as you can.
Have your friend make another mark on the ground at this point, and measure the line between the two points on the ground.
This is the wheel circumference, and if you do this with normal tire inflation and with your full weight on the bike, it's the most accurate way to calibrate your cyclocomputer.
If this helps, please be sure to hit the "thumbs up" for me.
If not, of if you have questions, use "add comment" to post back here, and I'll do my best to get you going.
2helpful
3answers
Whats the largest size wheel i can fit on my 2001 suzuki swift gls?
155/70R13 is stock but if it doesnt rub you could try a littly bigger but not recommended
I am trying to print a manual for a TI 36X Solar
Here it is in GIANT size:
http://www.datamath.net/Manuals/TI-35X_US.pdf
1helpful
How to calculate cable size
This site may help. Plug in all the information about your load requirements and it will figure out wire and breaker size and even how big a conduit you'd need for the run.
2helpful
Tire size for mitsubishi outlander
Here's a good tire calculator and it gives you the speedo changes etc.
Tire calculator
14helpful
5answers
Pump Size How to Calculate
Pump Size Calculation: Gauging the correct size for your water garden pump will ensure your pond receives the proper water circulation. Unless the pump you buy is already configured with a built-in fountain head, you'll need to calculate how much a pump can handle before you choose a certain size or model. A good rule of thumb is that pumps should be able to pump out about half the pond volume every hour. So a pump that moves 500 gallons per hour would be appropriate for a 1,000 gallon pond. In order to determine the size pump you'll need, you must calculate several key measurements.
Top Sigma Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Sigma Cycling Expert? Answer questions, earn points and help others
