Refrigerators Logo
p
ppihana Posted on Jul 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator not cooling.
Fridge troubleshooting: This is an Amana Side-by-Side Refrigerator/Freezer approximately 8 - 10 y/o. The freezer door was left ajar all night resulting in total loss of cooling. Visual inspection revealed no obvious damge, leaks, or issues. The condensor coils are clean and not blocked. This is the first problem we've had with this appliance. My limited troubleshooting skills resulted in the following after unplugging the fridge for 24hrs, then plugging back-in: Interior lights: On Compressor: On* Condenser fan: On Evaparator fan: Off *After 1 minute 15-30 sec the compressor shuts Off. **Advancing the Defrost Timer shuts down the condensor fan but the defrost heating element does not heat up. My assumptions: 1. Since the compressor and condensor fan will start the quick start capacitor and associated systems are ok. My questions: 1. If the evap fan fails to come on does this inhibit the evap fan from energizing and shut down the compressor? 2. What else would cause these symptoms?
Bob L
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 413 Answers
  • Posted on Jul 27, 2015
Bob L
Expert
Level 2:
Mentor:
Answers
413
Questions
Helped
75686
Points
735
No the evaporator fan not running has nothing to do with the compressor. I would suspect that you are freezing up over the evaporator because the fan is not running and when it ices up the air can not flow through properly therefore causing the refrigerator side to get warmer. Replace the fan and you should be fine. Take the back panel inside the freezer off and see if you are all iced up. If you bare then I would replace the fan . You also said the defrost heater did not come on. That will also cause a freeze up. Possible replacement of the defrost heater may be needed. Good Luck!
Amana fridge is not cold
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
My amana refrigerator is not cooling, freezer is working
Have an Amana fridge, 22.6 cu ft, 12 years old, side-by-side, water/ice on door. Freezer quit working over a 3 day period. All the food thawed. Not sure if the fridge part is getting warmer also -- not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Freezer is cold, fridge side is not. Fan runs, compressor seems to run. water puddle on the floor on fridge side. anything available for DIY?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
I just moved into an apartment that has a side by side amana 22 refrigerator in it. The freezer section is fine everything is frozen and the tempeture is where it should be. The fridge side however, is...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
