Question about Garden
Cranks but dies after 2seconds....why
Have cleaned Carb.and tank installed new gasket and diaphragm cleaned plug and put in fresh gas
  • 3,519 Answers
Hi Vernon:
It sounds like a fuel delivery problem.
Is there a fuel filter? Could be plugged.
Check that fuel flowing through carb. Drain plug?
When carb serviced, were all small orifices clean out (compressed air?)
Posted on Jul 25, 2015
Testimonial: "I tore engine apart and found problem was a cracked intake replaced it and now it runs like a champ thank you for your help"
6ya staff
SOURCE:
Why won't the saw run other than when the choke is in the 1/2 position and dies whenever throttle is applied?
Your carb is starving gas from your saw. You will have to remove the carb. and take it apart, check the diaphragms for hardening or splitting, clean all passages and screen. There is a lot of small parts that have to be put back together correctly, also the diaphragms and their gaskets have to be installed right.
Feb 27, 2015 | Poulan Pro Pp5020av 20-inch 50cc 2 Stroke...
I have A briggs & stratton 300 engine. When I start the motor surges at idle and full throttle.
Leaking head gasket or intake gasket
Try a new spark plug & fresh fuel first,
& clean the air filter
Sep 26, 2014 | ROPER OUTDOOR POWER PRODUCTS Weedeater 20"...
Working on a Briggs and Stratton 10T502-1457-B1. Runs rough and has black smoke coming from exhaust. This engine has no float to stick so that is not the problem. It does have a fuel primer bulb that works...
if you replaced the diaphragm and gasket below the carb and are completely positive they are installed correctly and not damaged, then the carb is defective and they usually warp or the primer system goes bad
Oct 21, 2013 | Briggs & Stratton Garden
Primes and begins to start, but then stalls out. Think it's a fuel supply issue. Good on oil and spark plug. Thoughts?
You probably need to clean the carb and possibly replace the gasket/diaphragm underneath it. If you are a do it yourselfer then you can do this. Otherwise take it to a professional. If tackling this yourself, first remove the gas tank and carb as one unit, be very careful to note where the springs are hooked up. Drain the gas. Remove the 5 Philips head screws holding the carb on. Underneath the carb will be a rubber diaphragm and gasket (careful; there's a tiny spring under there; don't lose it!). Spray out the carb with carb cleaner and spray out the little holes and cutouts on top of the tank. Replace the gasket/diaphragm (about $3 USD) and put it all back together. I hope this helps and best of luck to you.
James
Jul 31, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
3.5 hp b/s edger motor replaced gas tank gasket, and carb diaphragm. will start and run if I pour gas in carb.. wont **** from tank
if this is a vertical crankshaft 3.5 then you may have the gasket and diaphragm inverted, the diaphragm must be against the tank, and the gasket against the carb for the fuel pump to work, also check the pickup tube screen for being plugged, water in the tank bowl or a film or varnish or oxidation on the main jet sock.
If this is a horizontal shaft, like a go-kart, all the stuff about plugged pickups and main nozzles applies, only big difference is if there was a lot of corrosion in the bowl under the carb, the main jet could be permanently plugged, also there should be a removable jet on the control lever side of the carb that will probably need cleaning as well, also when removing the carb from the tank make note of any fuel in the bowl, if there isn't any, make sure the pickup tube isn't plugged or split, the diaphragm spring is installed, and the bowl doesn't have a hole rotted through it.
May 30, 2010 | Garden
My Husqvarna 350 chainsaw won't stay running. Changed spark plug and fresh gas. Please help if
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 25, 2009 | Husqvarna Garden
Starts but dies after several seconds
1) spark plug
Chain Saws:
Remove Carburetor
Nov 21, 2009 | Homelite Garden
It would not crank up so i replaced the filter in the gas tank and seemed to have put it back together right
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
1) spark plug
Chain Saws:
Remove Carburetor
Nov 14, 2009 | Garden
Yard machine ym26ss straight shaft trimmer. New gas,
1) spark plug
Chain Saws:
Remove Carburetor
Nov 12, 2009 | Yard Machines Garden
Garden Logo
141 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
