Check the connections: Make sure all the cables connecting your TV to external devices are properly plugged in and secure.
Adjust the backlight settings: Access the TV's settings menu and look for the backlight settings. Try adjusting the brightness and contrast to see if it affects the picture.
Check the power supply board: If the TV is not receiving sufficient power, it can cause issues with the backlight. Check the power supply board for any signs of damage or wear, and replace it if necessary.
Test the backlight: Use a flashlight to shine on the screen and see if there is any image. If there is an image, it is a good indication that the backlight is not functioning properly.
Replace the backlight: If you have confirmed that the backlight is faulty, it may need to be replaced. This is a more complicated repair and may require professional help.
If none of these steps work, it is possible that the issue is more complex and may require further troubleshooting or repair.
The issue you're describing with your TCL 55-inch QLED Smart TV, model U55X9006, where you can hear audio but the screen is black, could be caused by a problem with the backlight or the backlight driver.
Here are some steps you can try to troubleshoot the problem:
Check the backlight settings: Make sure that the backlight settings on the TV are set correctly and that the backlight is not turned off.
Check the backlight driver: The backlight driver is responsible for controlling the backlight, so check that it is functioning properly.
Check the backlight inverter: The backlight inverter is responsible for providing power to the backlight, so check that it is functioning properly.
Check the video signal cable: Make sure that the video signal cable is securely connected and that there are no damaged or loose wires.
Check the T-con board: The T-con board is responsible for controlling the video signal, so check that it is functioning properly.
Inspect the screen: Check the screen for any visible damage.
Contact TCL customer service: If the above steps did not resolve the problem, it is best to contact TCL customer service for further assistance and repair options.
Hi Jason,
Generally there are two reasons for no backlight in LED TVs. Either it is the inverter which produces necessary power to drive the backlight stops working or some of the LEDs in the backlight array fail. In some TVs even one failed LED will cause no backlight.
Can you see your screen when you hold a flashlight to it? If so then it may be an issue with the power inverter. I have the same issue on my laptop. Unfortunately It is hard to find the proper Inverter online. Hope this helps!
Related to a capacitor blowing up on your powersupply that supplies the voltage for the backlight inverter. The backlight inverter lights the tv. The power supply will need to be repaired so it can supply the 24v needed for the backlight inverter to work properly.
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as
they contain potentially lethal voltages that must be properly
discharged before work can begin.
I think what your monitor is experiencing right now is because of the backlight inverter in your lcd monitor is about to give up...The backlight inverter is a cold cathode light thats responsible for the image in your screen.. if the lights located on the upper and lower edge of the monitor will be busted then what you will see is black screen.. You will need to replace that in your monitor.
However, without the proper skills to do that and proper tools to open the monitor.. it will be risky for the safety of your monitor..
I suggest that you bring your monitor to a credible technician to replace busted backlight or (burned high voltage ballast transformer - supplying current to backlight)
1. backlight is dead (search for replacement displays).
2. backlight power-inverter is dead (check ebay for your model +inverter to see if there is even one in your model)
3. (very unlikely) wires which power the backlight may be worn from bending over time.
for the time-being, connect an external monitor, if possible, so you can access your system. connect it, power-on, and it should work by default -if not, hold the Fn key and press F8 (usually this key) to enable external display output.
1)the backlight is not working because there is some loose contact inside the board is not fitted properly... or may be it is misplaced due to some accidents like falling on the ground something like that........... if you are good at opening cell phones then just refit it .. this solves the backlight problem.... if not just take ur cell to technician....
2)after you refitting this problem may also get solved.....
but there is one more instance... 3) may be the operating system software has got corrupted.. & some files which are needed 4 operating have became unstable this is may be due to the virus attack... the virus attack may be due to transfer of datas like songs etc from pc or from the other cell via bluetooth...
so just visit technician and give it for flashing.... (means installing new software)
