Is there a controller for the fans or a separate thermostat?
SOURCE: Both ovens and the grill switch themselves off
If you have the handbook, it has sufficient information to enable you to get to the parts that you may need to check. However, working out what has failed is a little more involved and will need someone with electrical experience with a meter etc to work out what has failed.
As an aside, the cut off devices for both ovens are separate. So if both ovens have the same problem, then it could be the cooling fan.
If you need a copy of the handbook supply an email address and you can have a copy via the BT Digital Vault.
