SOURCE: 9120 Battery Failure
sounds like inverter is unhappy(causing the input fuse to blow. maybe, just maybe, this Powerware 9120 has given up the ghost? The inverter can short for a variety of reasons. Try to take out the battery completely, and run it as just a power conditioner. If that works, then you have an unhappy inverter in there.
SOURCE: Powerware 9120
Greetings!
How many years is your ups working? UPS is usually run by a battery, some of them are disposable and needs replacement. If it does not charge anymore it needs replacement of battery.
Thanks.
SOURCE: i need a manual for a powerware prestige (1250p2se)
old school hollywood baseball old school hollywood baseball old school hollywood baseball
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
SOURCE: Powerware 9120 BUS Unbalanced error display
I've had this same issue what it boils down to is that the Power IN is not being distributed properly across the Power Outlets.
Step 1. unplug everything from the unit and power the ups down. If the alarm clears itself the UPS is mostly likely fine. if it doesn't not clear send it in for repair
Step 2. If step 1 cleared the alarm try distributing the decives across the outlets differently.
There are two inverters so two output if everything is plugged into one side (ie a power bar with 10 things plugged into it) and nothing on the other side this could cause the alarm.
hope this helps
