SOURCE: it keep come up error code 51330 everytime when i
Error
Code: 513
Specific Error Code
Not Found - General Troubleshooting
SOURCE: am trying to download netflix disc. keep getting
Someone done this and you should try geting a aplucason
SOURCE: I am trying to update my wii so i can get netflix.
If you get an error code of 32002 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem: 1.Try using a different channel on your router and update your Wii to take to the router on that channel.
2.If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3.Make sure the MTU values on your router match those entered on your Wii.
Also note that if you make changes to your wireless router and you have a computer that uses that router too, you'll need to update your computer to match the new settings on your router.
SOURCE: Hi. I am trying to
Goto settings date and time and tell ps3 you are on daylight savings time. Then delete Netflix and reinstall.
SOURCE: Error code 52230 Can not connect up on wii to
This error is an issue with your router's firewall. You can find Nintendo's help on this error here:
http://www.wiierrorcodes.com/wii-error-52230-52232.php
One of the best ways to fix this would be to set up a static IP address on your Wii that is outside of the DHCP range of the router and then open up your router settings and configure a DMZ to point to that IP address. This will place your Wii completely outside of the firewall.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
