Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
Posted on Jul 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony mod# KV-34HS420 - won't come on - red led blinks 7 times...
... all that happens is the typical sound of the tube coming on but then it just goes off again. The little red light keeps blinking.
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Jul 12, 2009
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336676
Points
2402
How many times does the light blink it is very important you mention it so that i can be able to help you.if it is blinking continously then that means your jungle ic301 the ik video path is defected have a tech look on your set for repairs,good luck
KV-34hs420 LED Blinks 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
1helpful
2answers
My KV-34HS420 won't come on and the Standby light
The system has found issues with your TV.. The only solution is to call in service. Tell them the 6 blinks.. it is a code for diagnostics. Sorry.. the logic portion of the TV is experiencing some kind of breakdown. The only suggestion that I can offer is to hard reset your TV to factory settings.. other than that you are in duck soup..
Sorry...
Stan Skaggs
Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
2helpful
Blinking red light 3 times on sony 34hs420
Ur high voltage transformer it dead.The big block of plastic with the red wire with a cap hook to the CRT(ur tv tube).It call the FBT,
the Flyback Transformer that thing it dead.
5helpful
My Sony TV: FD Trinitron Wega - Mod. No. KV-34HS420 won't turn on. The red LED near the power button is flashing 7 times, then it pauses and flashes 7 times again. When I turn the power on it just makes...
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Sony KV-34HS420 Random Shut downs
i would say this is a internal problem how long have you had it?
7 flashes on my 34HS420 Sony TV
7 blinks indicates problem of Horizontal deflection failure. Possible cause can be Horizontal Out Transistor and / or Fly-back Transformer shortage.
If you have TV repair experience and electronics knowledge background, let me know to guide you more OR take TV to local TV repair shop for proper fix.
Standby LED blinking 6 or 7 times and TV won't turn on
That is an error code that tells the tech where the problem lies. It is probably somewhere in the power supply stage. Your best bet is to take it to a TV repair shoppe and let them deal with it. They have all the documentation in order to repair the unit, and they can tell you what the problem is before they work on it.
Cheers
15helpful
2answers
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
