Question about Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007
I have a 2006 c230 where is the fuse for the horn or whats the problem
It was working now it stop
  • jr gaiter
    jr gaiter Jul 23, 2015
    please help somebody anybody everybody
    Top Expert:
  • Mercedes-Benz Master
  • 6,815 Answers
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Posted on Jan 29, 2019
SOURCE:
Horn on 2006 Dodge Stratus does not work. What do I do to fix it?
I would say a new horn
Put battery voltage directly to it
& see if it works
If it made any sound-- how could it be a fuse ?
If it was a fuse, nothing would happen & a new
fuse wouldn't do anything, until you found & fixed
the reason a fuse failed
Sep 29, 2014 | 2006 Dodge Stratus
Horn has stopped working on my 2006 Ford Explorer. The fuse seems to be fine. What could be the problem?
I would suspect an underhood fuse, the steering wheel clock spring, or a wiring problem. It's cheap to triple check all the fuses. The other two will require some troubleshooting to figure out. Since the horn works with the keyless entry, the relay, the horn, and its control wiring seem to be ok.
Sep 20, 2014 | 2006 Ford Explorer
Horn on 2006 taurus stop working yesterday - fuse is OK - what else could it be?
Check the connection at the horn. It could be dirty, lose or corroded. There may be a relay for it somewhere.
I don't where the horn is located, usually up front around the grill.
If you are handy, try unplugging the horn and run a jumper wire from the battery to the horn and see if it honks. I don't know if your horn grounds by the mount or of you need to run a pos and neg to it.
Sep 18, 2010 | 2006 Ford Taurus
Saturn Ion 2006 problem with the horn
check the horn relay # 25 ; located underhood in the fuse and relay box.
May 05, 2010 | 2006 Saturn ION
My horn stopped working on my 2006 Toyota Scion SB
most new cars have what is called a clock spring be hind the steering wheel.this is a flat ribbon cable like what you would Se in a computer.what can happen when the ribbon is damaged is the horn can quit working.the cruse control .and the air bag light will come also.but most likely one of the problems will occur.but over time the other problems start happening also.so are you sure you are getting power to the relay .use a volt meter on the terminals under the relay and have someone to push the horn button.this will tell you if you are getting power from the horn button.
Oct 21, 2009 | 2006 Scion xB
Horn not working
check fuse then check relay or just check for power on the horn it self
Apr 01, 2009 | 2006 Toyota Corolla
Volkswagen passat 2006 fuse box layout
works manual only ,not given out to stop weekend mechanics form working on cars,
Oct 27, 2008 | 2006 Volkswagen Passat
Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007 Logo
37 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
