problem with my generator Honda EU3000
Generator Engine Leaks Gas
AND YOU MIGHT CONSIDER READING THE LINK BELOW AS WELL FOR ADVISE, TIPS AND TRICK.
About those generators Tips and tactics to keep it running through the...
SOURCE: does the honda 3000 generator
there is a screen in the tank at the shutoff valve best bet it to remove it and tear it out and use a in line filter where it is easier to replace
SOURCE: gas in oil
First of all check to see you have a good spark, If it is running fine under load ignition should not be an issue. If un burnt fuel or over fueling causes the oil / gas to wash down the cylinder walls. I would also perform a leakdown test not a compression test, remove the dipstick and listen for air coming out the crankcase, that will give you an idea if you ahve a ring problem. Also remove the air filter and see if you have any blow back from the carb blowing out where the choke butterfly is. If it has less than 150 hours on it, the rings may also not be seated in, try the above then run it hard on load and check it again
No, as with most small equipment engines, the culprit is the carburetor. You'll need to soak it in carb cleaner overnight in a sea;ed container and install the rebuilt kit for it.
