M
Manuel Arreaza Posted on Jul 23, 2015
How do I turn off the keypad beep? - La Crosse Audio Players & Recorders
I want my keypad numbers to beep when dialing
Go to general setup in the menu & turn on the keypad beep.
Honeywell ADEMCO 6150RF keypad sporadic constant beeping
It is trying to indicate a problem with zone 1. check it out.
Can't turn off beep sound on keypad of my stack-on Security Safes Electronic Lock for a 16 gun safe
You can turn off the "Beep" sound of the keypad by entering the code 633.
To turn the "Beep" sound on, enter the code 66
1helpful
GE microwave that will not stop beeping
he most likely cause of this problem is a keypad on the control.
You can try the stop/clear keypad to silence the beeping.
You can put the controls into child lock and see if the intermittent beeping stops. The instructions to turn the child lock feature you have it in the owner manual . The child lock disables most keypads.
otherwise replace the control board.
God bless you
1helpful
How do I turn off the beep when I hit a key on my motorazr V3xx?
Hello Sir !! Welcome To Fixya !! To turn off beep sound its quite easy.Just follow the simple steps are you are done : Go to Menu Then settings >ring styles > style detail > keypad volume.Bring keypad volume to zero and beep sound is gone.Enjoy !! IF this was help full please rate or token of appreciation will be esteemed.
I have a motorola rdm2070d radio and am trying to turn the keypad tone back on
Keypad Beeps
Keypad Beeps can be enabled/disabled by
short pressing SB2 button (until radio 'chirps')
while turning ON the radio.
Here is a link to the user guide: http://www.astracomm.com/media/pdf/RDX_Display.pdf
Best regards.
20helpful
2answers
I can't turn off the keypad tones on a LG Xenon phone
To turn off the beep on the keypad beep or voice on an LG Xenon, go to menu; settings; sound; volume. From there you can raise or lower the volume or mute the keypad and other sounds.
3helpful
2answers
Cant get the beep sound off when keying it
i helded the {+} at the same time i turned it on and it seems to take the beep off i guess will see if it happens agian , thank you for your help maybe i"ll be calling you again. kenstoy67.
2helpful
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 • Ovens
How to turn off the keypad beep
For the 6.0 gig phones, the manual explains in the handset set-up how to turn the keypad beep on and off. I rather like it as it serves as an audible indicator that the key was hit. Otherwise it is possible to have missed a digit. Of course, you can see the number on the display, but who looks?
Top La Crosse Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a La Crosse Audio Player and Recorder Expert? Answer questions, earn points and help others
