If it is a fairly cheap unit there may not be an area where you can adjust the speed of the turn table
on better machines there is a variable rheostat where by you can adjust turntable speed
quality machines will have the edge if the turntable marked with what looks like bars
This is not decoration but when viewed under a light bulb will appear as stationary bars when running at the correct speed or as a blur when at the incorrect speed
It works like this
the bars are in effect a strobe that is affected by the light frequency or power hz so that when the strobe affect is exact the bars appear stationary
( like disco strobe )
so if your player has these bars on the edge , then check the actual speed with a bulb light Remember stopped bars is exact speed
If the turntable doesn't have these bars then most good home entertainment shops will have a paper plate that can be put on the turn table and the effect will be the same
other than that talk with a good radio repairer shop and have the variable control installed in the power circuit for the turntable motor .
SOURCE: Speed increased +3rpm every half second
You have drive issues. There is no easy way to fix or to isolate the problem. You'll have to take it to a service technician who can test your unit, and fix the problem. Usually it's one of the 3 main IC (integrated circuits) which cause this problem.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
