Here are the steps to replace the charger for the Power On Board 450 amp VECO12POB jump starter:
Unplug the charger from the electrical outlet and remove it from the jump starter.
Locate the charging port on the jump starter and remove the cover.
Disconnect the old charger from the charging port by gently pulling it out.
Take the new charger and insert it into the charging port until it clicks into place.
Replace the charging port cover.
Plug the charger into an electrical outlet and charge the jump starter according to the instructions in the user manual.
Note: Be sure to use only the manufacturer-recommended charger for the Power On Board 450 amp VECO12POB jump starter. Using a different charger can damage the jump starter and void the warranty.
first of all these tablets take a long time to charge. second check the cable were you plug into tablet to make sure the holding clips are working and take hold. My first choice and most inexpensive is to buy a new charger. Also check plug in port for damage. look at warranty to see if it is still covered and get replaced. />
1. Remove front cover by sliding front panel down.
2. Install 4 new AAA (LR03) batteries (sold separately) and replace cover.
3. Turn unit on by sliding ON/OFF switch towards USB port. LED will
illuminate.
4. Plug USB charging cable (sold separately) into the Emergency Power Pack's USB port.
5. Plug the other end into your mobile device. (Make sure you do this last, as a few devices will not recognize the charge otherwise). Your device is now being charged
You may need a new power cord or it is possible that your Kindle Fire's battery has died. If you noticed
the battery life diminishing before it wouldn't charge this may
be the case. Here is a site that has replacement batteries for the
Kindle Fire: 3555A2L Battery for Amazon Kindle Fire D01400
Since You have changed the charger and the battery and the phone still does not charge then It means the charging/connection port of the phone is bad. And the best solution is to replace the port of the phone. To replace the port is quite simple. First You can charge the battery in another phone temporarily while You get the connection port of the phone fixed. To replace the connection/charging port, please follow the steps below:
First remove the back cover and battery.
Unclip the front cover then remove the four circled screws
You can now remove the LCD frame. Another ribbon connector (circled) needs to be disconnected. This attaches like a plug and socket. Simply lever it up, away from the phone, to unplug it. The LCD is now free.
Then You take out the 4 screws that are around the phone,
That should release the panel of the phone out,
Disconnect the connection port of the phone and replace it with a new one,
Then You reverse the process to reassemble the television back together.
The problem actually is not from the charger, it is from the charging port of the phone. The pins that are in the charging port are wearing out that is why you have to adjust the charger before it will stay in.
The only solution to that is for you to replace the charging port. To replace the charging port, get the appropriate screwdrivers, then you remove the phone cover, the sim and the battery, then you unscrew the phone, try to separate it apart to locate the charging port, then you replace it with a new one, after replacing it, reassemble the phone back together and it will be in good condition once again.
