If you look at the First picture on the TABEO User guide it is a little hole next to MicroSD slot on the side of the tablet
the user Guide is here
http://tabeo.support-tablet.com/download/e2/e2-startup-guide.pdf
I had the same issue with a toshiba. I opened up the laptop and put a cut piece of wood that fit behind the connection. that prevented it from falling out when the charger was connected. tape will help hold things in place.
Can you get it out far enough to put a "C" shaped piece of plastic under it so it won't fall back into the hole? Or wrap some tape around it, or some string?
Ive got a 92 Tercel. Had this same problem. Look around on the floorboard of your car. Look for a small rubber disc, or broken up pieces of the rubber disc.
If you see the pieces or whole hard rubber thing on the floor, then the rubber disc that goes at the point where the brakelight switch touches the back of the brake pedal has fallen off.
When that disc falls off the brakelight switch touches bare metal, and the switch is grounded which makes it stay on all the time.
Climb under the dash with a flashlight and look at the back of the brake pedal. Find the brakelight switch, look at the point where the switch contacts the pedal. See if the rubber disc is missing. If it is missing find a small piece of rubber to superglue on the spot where the switch makes contact.
If the disc is there the brakelight switch is probably stuck. If its stuck you will see a gap between the switch contact and the brake pedal. If its stuck get a replacement brakelight switch from an auto parts store.
remove the bottom tray that you sit your glass on, push down on the bottom of the trim arround the despenser, lift outward then upward on the trim panel, have a piece of duct tape handy to tape the panel out of your way to gain access to the assembly
A White Clip On The Rear Has Fallen Off... It Pushes A Micro Switch On The PCB (Printed Circuit Board)... Poke Your Finger In The Middle Hole At The Rear Of The Grey Tray While You Have The Lid Open... Feel The Switch And Press It... (Tiny Button) You Will See I Am Right... Try To Locate The Piece That Has Fallen Off... Glue It Back On Or Order Spare Part... Or Bin The Printer (Lexmark Is Useless) (Buy Epson)
I Hope This Helps!
Lance Smart (Currently Trying To Resolve The Same Issue)
