Troy Bilt 5.5hp Self Propelled Mower Logo
Kade Markoux Posted on Jul 21, 2015
Lawnmower Makes Squealing Sound when Self-Propell is Used
I have a brand new troy built self-propelled lawn mower and it starts up fine... However, I prefer to use the self-propel to make it easier so I don't have to push too hard and for the last 2 times that I have since tried to use it my lawn mower then suddenly starts squealing so annoyingly that I can't stand it and don't want to use my lawnmower anymore... Any ideas what could be the problem? I was debating taking off the top and looking at the belt to check it but I'm not sure what would be a good place to start especially since it is a brand new 2 month old lawn mower that my mom got me as a housewarming gift...
HOW TO REPLACE DRIVE CABLE ON TROY BUILT 12A466MO11
Parts Finder Search Results
46 732-1043 Belt Tension Spring open the above link above and zoom in as much as possible on the diagram. Find part #46, which is the belt tension spring. Now locate it on your mower and look at the whole mechanism , where the pulley is. Check to see if it engages when the cable is put put into drive. Order new parts as needed.
My self propell lawn mower stop propell
the cable needs tension to engage the belt tensioner
Sep 23, 2012 • Garden
Troy bilt self propell model# 184986 need throttle cable, cant find
look on sears parts online but a lot of newer mowers they don't use them anymore
Self propell will not go
Remove the cover from the self propel and check the engagement cable for excessive stretch.
Also check the drive belt for wear or breakage.
Self propelled #860. self propell got slower and slower. now barely assists. can I adjust the belt. manuual says bring it in. too far. how do I tighten? thx, bruce
Your self propell is not adjustable. The belt runs over a spring tensioner,you either need a new belt or axle bushings. If you pull the top cover off, you can watch the belt when you engage it. With the engine off, can you move the front wheels up or down or forward or backward? If so the plastic bushings are worn out and this changes the geometry of the drive system, making the belt appear too long.
Hope this was helpfull, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
1helpful
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
The self propell won't engage
the cable may be broken or disconnected - we replaced ours - just needed to buy a new cable ($25) and replaced it myself :)
3helpful
2answers
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
2answers
Troy bilt lawn mower. Will not engage self propell, front wheels
Hello:
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
85helpful
3answers
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
