Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
D
David Rutherford Posted on Jul 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why won't my rider move and keep running?
I quit mowing. On restart the wheel locked up and engine doesn't stay running.
richie46
Level 3:
Top Expert:
  • Toro Master 12,962 Answers
  • Posted on Oct 29, 2015
richie46
Toro Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945920
Points
58151
Something is jammed in the drive and when you put the mower in gear the motor stalls. U need to locate the source of the problem - once you do that all will be copacetic.
1 Related Answer
Anonymous
  • 23 Answers
  • Posted on Aug 15, 2011
SOURCE: engine starts but won't continue
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
My ariens ex rider dies if the levers are moved or
if engine is dieing then try govenor adjustment to keep running
Sep 07, 2014 • Garden
Sears lawnmower kills after mowing for 10 minutes doesn't restart till rested a long time. Repair man says nothing wrong with it.
That is the symptom of a failing ignition module. With the airbox cover and air filter removed run the unit till it fails. Immediately squirt a shot of carb cleaner into the carb and try to restart. If it restarts see if you can keep it running on the carb cleaner for a few seconds. If it wont restart or stay running then its likely an ignition module. If it does restart and keeps running on hte prime then you have a fuel issue.
Other things to check: spark plugs can fail when they get hot, checkt o make sure the engine stop cable is pulling the bail off ground sufficiently. If the cable has stretched it may not pull the bail completely off ground causing intermitent spark.
Nov 17, 2012 • Garden
1helpful
Rider loses power after mowing for 30 - 45 minutes. Gets to a point, it won't climb a small incline. Engine sounds good & the deck runs fine. Just won't go.
Hi, the hydrostatic drive is most likely over heating. Remove the battery and battery carrier, from here you can clean all grass and debris from the hydro cooling fins and fan. Hope this helps, regards Phil.
Rider steering difficulty
First inspect all the steering parts. Inspect them closely and see if anything is worn to the point it is binding. Lubricate all moving parts. See if anything is bent or rubbing against another part. It is obvious it is only hard to steer when weight is on the front. That is a clue to what is going on. It is just a matter of looking very closely at what moves and what can cause something to no move as it should.
Oct 06, 2009 • Garden
2answers
Murray rider quit abruptly.
were you mowing at the time? if you didn't disengage the blades, the engine will not start, everything will seem "dead". if that's not it, check for a blown fuse
Honda 2001 ex stopped running and steering locked up
you say stopped running steering locked up the steering lock is mechanical and has nothing to do with the actually running of the engine so i am presumming that the car was idling stalled on its own and the steering as you tried to restart it locked or the steering won,t turn it won,t if the engine s not running as it is helped by the power steering pump which doesn,t work unless then engines running but if the steering has just locked up then you won,t be able to turn the steering in which case you,ll need a new steering lock not that big a job yates210456
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
