Toys Logo
Posted on Jul 11, 2009
Hi i have a blast 10 boat w/ brushless motor an mystery esc. w/ battery pack. everything works except motor runs in the right direction but only works when transmitter is in reverse. motor wont run w/ trans. is foward. thank you vinny
  • tuffpony000 Jul 12, 2009
    this brushless has 3 wires in the back. A,B,an C.
    which ones do i reverse?
    thanks
  • tuffpony000 Jul 13, 2009
    txs for all the help,,reversing didnt help. im new at this n what i learned is, motor an controller should be together. what i saved in money i loss in stress.lol
    thanks again
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jul 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
1699
Points
24
If u can get to them, try reversing the wires going to the motor. this works well on rc cars. hope it helps, good luck
  • 1 more comment
  • Anonymous Jul 12, 2009
    All 3 wires will provide power to the windings but only 2 are energized at any given time. the 3rd wire provides feedback to the esc. Swapping any 2 wires will reverse the rotation of the motor. Hope it works out for you!
    also the older stick handsets are set up in reverse, no idea why though. Pistol controllers are known to work well. You could try www.rcuniverse.com for help on setting things up with your speed controller. thats all i can tell you unfortunately. i hope some of this is useful to you Vinny
    sorry, forgot to mention rumrunnerracing.com have a great forum which can usually work out any problems u have to do with r/c boats
1996 70 hp johnson outboard ,,need to know why the motor rise up when I put it in reverse and give a little speed to back up, and when I let off the speed the motor goes back down.
In reverse, the propellor is pulling the motor away from the boat, this is the same direction as the motion you get when you tilt the motor up for transport. Check the motor mount, especially the motor tilt mechanism to make sure nothing is excessively worn, bent or loose. Maybe the latch that's supposed to hold the motor in the run position isn't working right - that could be bad news if it lets the motor drop down while the boat is on the trailer.
Jun 26, 2015 • Boating
2answers
Problem to connect walkera cb100 esc controller connector
there are only 3 combinations on connecting esc to brushless motor. if nothing indicated on wires you can try each combinations of 3 wire by keeping 1 wire choosen and trying rest 2 wires. dont worry you wont burn anything. only motor runs on other way.or it wont move but makes noise.
Nov 18, 2011 • Toys
When I plug my new Eflight 32 motor into the battery I get a constant beeping sound and the motor will not initialize. It was working until I unpluged it after binding the controller to my hand held...
Check your TX throtle stick is completly down. ESC beep if they detect signal from throtle channel on start.
Other cause could be you plug ESC in wrong channel in your RX
I want to connect 2 brushless motors tegether mechanically to get a long thin motor. Will it work ??
If the two motors are the same model, or are at least designed to run at the same rpm, then yes it will work. Achieving a very close alignment of the two shafts will be the hard part. I assume the motors have an exposed shaft at both ends and that you will use some kind of collar to connect the left end of the shaft of one motor to the right end of the other. You will need to mount both motors to a block or bracket of some kind. Use rubber grommets or something similar to mount the motors to the block pretty loosely so that you don't exert misaligning pressure on the two shafts. You should get nearly double the torque and power that you would get from one motor. If it runs slowly or obviously has low torque, the alignment is not good enough. Good luck.
Hsp bruchless
Hi there
I have the same electronics on hsp rally monster pro. 3300kv - but 75A ESC, i upgrade it to 6000kv with 5000A lipo without any programing to the ESC . it worked fine for couple of runs but i faced wires over heating problems after that something wrong went to the ESC !!! . .
Am going back to 3300kv, but need advice of what is the higher ampers/voltage battery can i use?
3helpful
2answers
Eflite 60amp esc - no throttle responce
Lower throttle trim all the way. It will arm like a charm.
Cliff
Hurricane 550 battery problem
Hi All,
Thanks for your reply.
Finally, I've solved the problem. The battery that I've got previously produced 42 volts each and I connected two in series configuration. So the voltage add up together become 84 V for ESC.
That's why I can only fly for twice and it didn't last for long. The batteries were bubble up and really hot, basically, I busty it. Besides, the ESC is cooked.
So, I bought two brand new battery packs ( 3C 11.1V 3300mAh) and an ESC. The ESC has built in switching mode.One of the socket from ESC is connected to the switch with black and red wires were wrong way around. After I've swap it everything works. By using this way, there is no needed the extra 9V batter pack for receiver.
Your Sincerely,
Joe
RIVA AQUARAMA PROBLEM
You should never run the boat out of water! The shafts heat up in the shaft tube and freeze up. Then your done.
I own a company "H2O Hobbies"
We sell ready to run Riva boats such as yours. Many other people sell these same boats from the same manufacturer in vietnam. BUT - These are display all models.
My company works with the manufacturer to create each model with removable covers to access the motor etc... inside. The models are made waterproof by lining the inside of the hull with fiberglass. We use high quality brushless motors (1) with hardened steel u-joint coupling to the shaft which is 4mm stainless steel and attach a beril-copper balanced propeller. This setup is bulletproof. It took about a year of testing several different components to find the right set of matched components to get the best performance and reliability.
We use 2 7.2v battery packs in series = 14.4v.
See youtube videos - search scalemodelpowderful.
My suggestion is to put your boat on a shelf because that is what is was made for and buy one from us which is waterproof and accessable to work on if necessary. Go to H2OHobbies.com or call me 612-325-2345 - Mark I am the Director of product development. I build the RC boats myself.
Top RC Toys Experts
NOEL
NOEL
john h
Are you a RC Toy Expert? Answer questions, earn points and help others
