Hi myatkyaw81, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? last mobo with IDE (pata) ports , ICH7 so disable those ports in BIOS and use SATA drives only. or learn the 20 year old art of IDE drive setup. DMA and PIO and all that jazz. master/slave, etc. all on page 36 in the free manual. asus.com page 45 too. see how to set auto there or to IDE type, CD or what is there,? if no IDE devices, disable IDE;. best is auto settings. there. https://www.asus.com/in/supportonly/P5G4...
RIP IDE for ever.Hi myatkyaw81, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
master/slave, etc.
https://www.asus.com/in/supportonly/P5G41T-M%20LX/HelpDesk_Manual/
RIP IDE for ever.
1 more 2009 mobo the coin cell battery dead can do that too. , 5-7year life. so 6 is smack there. less if mobo stored in a box in the hot attic for 3 years. and all bios setting lost. easy fix but lost. (new coin, reset bios) IDE off sata set as it was,? SATA or AHCI, ?
no PC load told ,what is there all, not told so cures , 100x hard.1 more 2009 mobo the coin cell battery dead can do that too. , 5-7year life. so 6 is smack there. less if mobo stored in a box in the hot attic for 3 years. and all bios setting lost.
IDE off
You can't post conmments that contain an email address.
Thanks. I'm writing about a sewing machine with programmable electronic options. Was hoping for something simpler and more specfific. CherylThanks. I'm writing about a sewing machine with programmable electronic options. Was hoping for something simpler and more specfific.
Cheryl
cheryl, this is asus, computer repair, post to Sewing machines,maker and model told https://www.fixya.com/troubleshoot/brows...cheryl, this is asus, computer repair,
https://www.fixya.com/troubleshoot/browse/sewing_machines
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
POST Beep Codes: OptiPlex GXi
If the monitor cannot display error messages during the POST,
the system may emit a series of beeps that identifies the problem
or that can help you identify a faulty component or assembly. The
following table lists the beep codes that may be generated during
the POST. Most beep codes indicate a fatal error that prevents
the system from completing the boot routine until the indicated
condition is corrected. Beep CodeError Probable Causes
1-3
Monitor not
detected
Disconnected or faulty
monitor
1-1-3
NVRAM write/read
failure
Defective system board
1-1-4
BIOS checksum
failure
Faulty BIOS or defective
system board
1-2-1
Programmable
interval-timer failure
1-2-2
DMA
initialization failure
1-2-3
DMA page
register write/read failure
1-3-1
Main-memory
refresh verification failure
Faulty or improperly seated
DIMM or defective system board
1-3-2
No memory installed
No memory installed or faulty or
improperly seated DIMM
1-3-3
Chip or data
line failure in the first 64 KB of main memory
DIMM
1-3-4
Odd/even logic
DIMM
1-4-1
Address line
DIMM
1-4-2
Parity failure
DIMM
2-1-1 through 2-4-4
Bit failure in
DIMM
3-1-1
Slave
DMA-register failure
3-1-2
Master
3-1-3
Master
interrupt-mask register failure
3-1-4
Slave
3-2-4
Keyboard-controller
test failure
Faulty keyboard controller
(defective system board)
3-3-4
Screen
Faulty video subsystem
3-4-1
Screen-retrace
test failure
3-4-2
Search for video
ROM failed
4-2-1
No timer tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected
interrupt in protected mode
4-3-1
Memory failure
above address 0FFFFh
DIMM
4-3-3
Timer-chip
counter 2 failure
4-3-4
Time-of-day
clock stopped
Bad battery or defective
system board
4-4-1
Serial-port test
failure
Faulty I/O chip (defective
system board)
4-4-2
Parallel-port
test failure
system board)
4-4-3
Math coprocessor
failure
Faulty microprocessor chip
or system board
4-4-4
Cache test
failure
Defective microprocessor or
system board
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
I'm not familiar with that particulat model, but I'd guess the motherboard has a chassis switch connector, and senses the chassis be open. Could be because:
- chassis open (close it),
- switch defect (as a workaround, you could short-circuit it, or just unplug it - whichever solution works for you).
As another workaround, you can probably disable this switch in BIOS.
very simple shut down computer put side panel back on and restart go into bios and under the settings somewhere you will see enable chassis intrusion. Just disable that. If you put cover back on then proceeded by turning power on and you still get this error than it is time to clear CMOS and then you must go into the bios and hit setup default and then go into any timings and voltage settings for CPU Memory and such. and also disable the chassis intrusion. You can enable it at anytime. just as long it is not powered up when removing side panel. I hope this is helpful.
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
master/slave, etc.
RIP IDE for ever.
IDE off
