Unplug it for a couple of minutes, Try again. It may have been hit with a surge. IF that is the case, you are looking at main control board and some money. Contact your homeowners insurance if a surge has damaged it.
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
What kind of refrigerator, and whats the model number? Green bar flashing I'm going to guess a Samsung. If so, then hold down two buttons at the same time on the display, It depends on the model number as to which two, but in most cases its the power freeze and ref buttons. If you can get the brand and model # to me I could describe more for you.
Try this procedure, it should help fix the problem, Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Samsung RS2555Sl suddenly stoped working once the power is switched off, If switched on again, only the Ice making sensor light flickers. If both Pwercool and power freeze buttons are pressed for 12 seconds it stars and running normally. Will it automatically start working if I change the Ice making sensor?
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Press feature key then dial #* password 000000 next, go to sets, hit show, hit next till ringing assingment is display hit show and change from n to y on line ringing assingment. do this for each set and line that need to ring.
