Usually a key symbol means that the appliance is safety locked. usually by holding down a button for 3-5 seconds to lock and holding down the same button to unlock. a child lock safety feature.
Testimonial: "Thanks. The child lock has an other symbol at gaggenau. However, we can open the oven now after switching off the electricity for a few minutes. Howver, the error f10 remains. What does it mean? The oven works. Is it dangerous to use it with this error? Thanks again for your help."
f10 indicates sensor issue:
Thermador®
Gaggenau EB 270/271/290/291 Oven Error Codes...continued
Note 1
Oven sensors should measure 1050 ohms at 75 degrees F. if the sensor measures correctly (within 10%), check each leg of the sensor to ground and to each phase of the electrical supply. If all checks OK, check the contacts inside the molex plug. If the spring contacts are bent or crushed, the sensor will create intermittent errors.
there are two lock symbols, one is child lock, the other is door lock. manualonline.com has your manual.
